There are a few differences, one being the sensor plugs on r32 are round, square on a31. Also the r32 engine has a little more power in stock form. The r32 has factory bov and a31 doesn't. I have heard there is more potential for higher power outputs from the a31 engine, not exactly sure how or why though. Not sure on if the turbos are the same
Edited by Love_Hate
The cefiro inlet cam has a longer duration and the exhaust cam is retarded about 2 deg from the R32 cam.
ceff afm, coilpacks and ignitor are different.
ECU also only has 1 fuel map and 1 timing map as opposed to the skyline. it has 2 fuel and 2 timing maps.
If you look at the 2 maps the skyline runs 3 deg more timing and has different load tp scaling.
thanks for all the replys so with these spitfire plugs can u get spitfire coils that u can just plug in to replace the stock coil packs over coil pack problems?
They are adapters. http://www.skylinesaustralia.com/forums/in...mp;hl=splitfire Seems Splitfire didn't want to manufacture different coilpacks for the same engine. If you could get hold of a R32 coil pack loom and are 1/2 handy with electrics you could easily knock some up yourself.
so that is only for the adaptors then u would have to get ur hands on some 32 coilpacks to plug in them or do u buy the aftermarket ones as shown on the pics below the adapters ?
the turbo is different also, R32 is ball bearing ceffy is plain bearing. also slight differences in the exhaust side.
later ceffys run the rounder R32 style loom plugs, but most are early ones
AFM, coils, CAS and some other sensors are the same as R31 Redtop RB20DET. turbo is also the same as that of a redtop.
loom (bar the plugs), injectors, head is all the same as r32.
while working on my dad's cef (series 1) I found that it had more parts in common mechanically (well, engine and electrics) with the R31 GTSR than it did with the R32 GTSt.
  • 4 months later...
i just found out that my R32 RB20DET engine is being run off a cefiro ECU...
can anyone tell me if this is dangerous for the engine?
i'm trying to track down an R32 ECU, but having no luck so far...
if anyone can help me by answering that question, it would be GREATLY appreciated... :D
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
