recently i just did my exhaust manifold gasket and studs etc, i bled the cooling system right but now when i drive the car smoke comes out of the catch can and whatever breather is on the rocker covers, its an oil burning smoke nothing too big. What can be wrong? any ideas?
thanks for any help
https://www.sau.com.au/forums/topic/148488-smoke-out-of-catch-can/
thanks for any help
rings
glazed bore
get ready for a rebuild soon
so my oil rings have had it? its running good still, compression is up to where it normally should b, oil pressure is good, runs healthy.
also, no white or blue smoke is comming out of my exhaust.
Does anyone know a definate answer?
Edited by LTHLRB
does it do it constantly? or just for a few mins or so when starting it... i had a similar problem, when there was a little bit of oil on the filter of the catch can, after about 2 mins it went to normal, also had no smoke out of the exhaust etc etc... motor was taken down and everything is in fine condition... if it does it all the time non stop then id start lookin at the rings etc
ben...
thanks for any help
basically thats what u would call blow by,every motor has to breath and yeh after a good hard floggin on boost mine does the same u pull up take your oil cap lid off and look at the motor breathing..my mate services cars at his workshop that only have 30,000kms and they have blowby, im guessin its just oil vapours nothin to be 2 worried about,once u start filling your catch can with oil on boost then be worried lol
its a std ecu with timing, doesnt ping and is on constant 11psi, i dont drive it soft either. But it does it constantly, a bit of smoke once u rev it it gets a little thicker. The catch can has no filter on it either. But not a drop of oil in the can ?
Catch can has no breather? does it pipe back into the intake pipe? or have you just got hoses going from the rocker covers to the catch can?
When I got my car all the breathing hoses were screwed up, there was a hose from the intake manifold to the rocker cover that was disconnected. This was causing it to pump huge amounts oil out the exhaust at high load/high revs. Once I replaced the hose from the intake manifold it stopped throwing oil out of the exhaust and starting trying to push it out the dipstick and felt like it hit a brick wall over 5000rpm.
My guess was that the crankcase was pressurising as the catchcan that came with the car didn't have a breather. To test this I redid all the breathing hoses and ran one just venting to atmosphere.. no more problems :)
Catch can doesn't fill up, oil doesn't come out of the open breather hose and it doesn't try to jump out via the dipstick, just pulls hard to redline :pirate:
Edit: hang on.. you said the catch can doesn't have a breather but in the first post you say there is smoke coming from the catch can??
Edited by bubba
I use a stainless steel scourer in the catch can to help the oil vapour condense.
I extended the inlet pipe side into the stainless steel, this makes the vapour flow through the wire mesh. THe outlet is unchanged on the top. Only down side is you can't let your catch can get to full [mine never does anyway].
umm. i take it it isnt smoke. but rather mist ? this is normal. it should at idle have a small but steaddy sort of stream of mist/steam coming out.
like a big cup of coffee etc etc.
Yer my catch can had a hole it in and I recently noticed it was letting out some "mist". Went away once you revved the motor, but once back on idle it came back. I take it this is normal? Because I hardly get any blow-by.
Btw I've sealed the hole now because it was actually being vacuum leak in my system.
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
