yeah that very true which is why when i do organise "cruises" i try to take everyones circumstances into consideration ie if they like to cruise in afternoon/night/wet/dry, to make it worthwhile and b/c i personally want everyone to be safe and happy with those they are cruising with.
  • Replies 6k
Posted Images
For the exception of Mark Phillips in Danny's old 33, still love the sound of that thing hitting limits!!
Only reason that its an exception is b/c its built to be drifted. so nothing out of the ordinary there. Im contemplating modded the 33 to those specs but unsure if im a drift wannabe right now or hp fanatic - gtr instead of modding the 33.
To set up a car drift is all in the suspention, you can have you car looking just as phat for grip racing with different sus parts for grip, power wise nothing has to be different!!
Just getting my front bar repaired because i got it 2nd hand with damage, oh and my small dent is getting fixed.
that gtr front bar your talking bout will?
i dont have msn atm. taking to u on a laptop that doesnt have anything on it.
adelaide uni has examns 1 week early then unisa, correct?
whens your 1st one or next one?
:werd:
but i still belive it takes more money to get a line particularly a 33gtst sideways than a silvia platform ie s13/14/15.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
