haha, yep, its unavoidable :D. it can't be that bad? at least i hope not.
I got mine out a few years back, went under a general, and had all 4 out in one go. Only way to do it.
I was sweet pretty much from day one, no major swelling or bruising, just couldn't open my mouth all the way. But it all depends on how heavily impacted your teeth are, mine were fairly minor.
  • Replies 6k
Posted Images
Whilst we are on the subject I thought I'd share a little bit of information with you and explain why having your teeth pulled out hurts so much.
The first misconception is that the teeth are pulled out; I was told this only works with young children loosing their milk teeth. It was explained to me that teeth removal is a lot like removing a post from the ground. By pushing a pry bar down next to the tooth, pressure is exerted on the gum and tooth. If you push down hard enough (the whole isn’t big enough for both) something has to give, and the tooth pops up.
This explains why you feel so much force when they remove teeth, I had always wondered why I felt I was being pushed into the seat and nor pulled out of the seat.
See the the trick there Cubes is you keep the gas on till you legs and feet feel tingly, then you say...."Yup, i can still feel everything"....
Then when you slur it the 4th time "Yus....icunsillfill maaahh legzzz" is when they KNOW to turn the gas down :P
Thats when id let em shove a needle in me :)
nothing mate. will probarbly get materials to sand back the sil80 - weekend is fixing car time. yay!
ur car at boostworx atm? btw did u know that when daniel got his car tuned there, apparently hasnt even paid for it and was allowed to drive it way. ????
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
