  • Replies 6k
Posted Images
nah sam, 1st time there if i remember correctly. something to do with the fact that since his ebc wasnt working properly the was allowed to drive off without paying a cent but will pay full amount when he get a tune with a working ebc. wierd.
nah, its still here. i cant get the work done until i can borrow my sisters car. shes on holidays atm. so once shes back at uni, i'll drop the skyline off and borrow her pulsar.
are you still in the process of gathering parts?
i drove it a few times. Gearbox is very funny in terms of shifting to say the least. But it has tidal waves of torque compared to the line. s2000 is a different story - it has an awesome gearbox. Shifting is go slick and fun in that car.
Bachelor of IT.
I'm in my 3rd year so yer exams suck. :(
Especially J2EE - Internet Computing.
I'm a fiddler. I only 'try' to improve upon the current cheap $100 tune I had.
I found that when changing gear or simply flattening it the map trace was dipping to load point 20 then once accelerating settling on load point 19 through the rev range.
This load 20 point was running ever so slightly too much timing as it was causing highish knock readings.
I reduced load point 20 by one degree and left load point 18-19 the way it was and knock went from 35 down to 17.
So.. I dialed in another degree in to load points 18-19 and found knock didn't rise.
That 1 degree makes it feel more lively, but only makes throttle control that little bit harder in second.
Basically through the mid range its now running 17degree's instead of its previous 16 and in some parts 15.
These new tyres don't hook up though. :)
I bought some Firenza ST-03's.
If I don't ease my foot in to it second axle tramps majorly. :D
My subframe bushes are screwed, first things first during the holidays, I'm going to fit some pineapples, hopefully it will stop the subframe from slopping about and help with traction a little.
If I still get too much movement, over the X-mas holidays I'm going to drop the subframe and fit a set of new subframe bushes from Noltec ($190 from Unique Autosports).
Maybe, a big MAYBE fit a S13 3.9:1 diff as to help the rb30 get that little more speed from each gear.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
