  • Replies 6k
Posted Images
nah sam, 1st time there if i remember correctly. something to do with the fact that since his ebc wasnt working properly the was allowed to drive off without paying a cent but will pay full amount when he get a tune with a working ebc. wierd.
nah, its still here. i cant get the work done until i can borrow my sisters car. shes on holidays atm. so once shes back at uni, i'll drop the skyline off and borrow her pulsar.
are you still in the process of gathering parts?
i drove it a few times. Gearbox is very funny in terms of shifting to say the least. But it has tidal waves of torque compared to the line. s2000 is a different story - it has an awesome gearbox. Shifting is go slick and fun in that car.
Bachelor of IT.
I'm in my 3rd year so yer exams suck. :(
Especially J2EE - Internet Computing.
I'm a fiddler. I only 'try' to improve upon the current cheap $100 tune I had.
I found that when changing gear or simply flattening it the map trace was dipping to load point 20 then once accelerating settling on load point 19 through the rev range.
This load 20 point was running ever so slightly too much timing as it was causing highish knock readings.
I reduced load point 20 by one degree and left load point 18-19 the way it was and knock went from 35 down to 17.
So.. I dialed in another degree in to load points 18-19 and found knock didn't rise.
That 1 degree makes it feel more lively, but only makes throttle control that little bit harder in second.
Basically through the mid range its now running 17degree's instead of its previous 16 and in some parts 15.
These new tyres don't hook up though. :)
I bought some Firenza ST-03's.
If I don't ease my foot in to it second axle tramps majorly. :D
My subframe bushes are screwed, first things first during the holidays, I'm going to fit some pineapples, hopefully it will stop the subframe from slopping about and help with traction a little.
If I still get too much movement, over the X-mas holidays I'm going to drop the subframe and fit a set of new subframe bushes from Noltec ($190 from Unique Autosports).
Maybe, a big MAYBE fit a S13 3.9:1 diff as to help the rb30 get that little more speed from each gear.
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
