  • Replies 6k
Posted Images
Looking at some of those bull’s eyes it may indicate you need a bit of bodywork or at least a high fill primer.
Did you say you are doing it all by hand?
It can be hard not to get rub marks in the car if you are doing it all by hand, can you at least get a block, or better still an oscillating orbital sander (air tool) to do the majority of the work. You will need to finish it off by hand, but to do the whole lot by hand is a big job.
PS any little imperfection will look 10 times worse with a coat of paint on it. Before you paint it get someone with a good eye to go over it and highlight the bits that need more work.
The first time I painted a car my preparation wasn’t good enough (after a week of work) and the car looked almost as bad with the new coat of paint on it.
hey guy,
thanks for the advice. yeah the bull's eye are obviously dents in the fenders. im using a block and all by hand. Its a big job but i dont have the necessary orbitor equipment so im just going to have to do without it. Im ust concentrating on the sanding atm and then will fill up the dents prior to applying the primer. I aint rushing it so should hopefully be ok.
:werd:
Heya Sleeper, do you have some spare time in the next month to come down to morepower and get my turbo high flowed? Would be good to show them that I want the same service you recieved for the same price etc.
no problem. :Pimp2:
I have a week of from the 9th to the 17th :uh-huh:
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
    • If you do make them, im sure you would have a number of buyers.. Every GTR I've been in have rattly door windows
