  • Replies 6k
Posted Images
all i have to say is nothing is a bolt on kit. It took most of the afternoon - we had to run around for food/misc duties. Performance? I wouldnt have a clue, you would have to ask will that but i recall him saying is that it doesnt make a difference which i then replied its just a safety modification.
btw do you remember the name of the filler that you were going to recommend for me to use on the car - its all sanded back now. Just need to fill some dents and its ready for primer. yipee
btw will is definately serious bout upping the performance on his car sam. When i was there i discovered his pfc, fmic - which we installed and oil cooler. Didnt see any aftermarket turbs though. His getting a tune tomorrow morning supposively @ boost worx.
yeah FMICs don't improve performance - if anything they degrade performance slightly, as they make cars a little more laggy (due to the car having to pressurise a larger volume before making boost). But, they are vital if you want to up boost, and they lower the intake charge temperature to help prevent pinging.
sam, do u want a cai box for your 33? Im going to get will's cai box - the one he bought of max, and fabricate it for 33's and 32's. I inspected it when we had to remove the air filter and its looks quite easy to do as long as i can get the materials. So are you keen?
so you hooked up the pfc too? whats going to happen with the oil cooler, is he gonna sell it or hook it up?
this is the exact cai box will has. I dont know if it does any good would it wouldnt hurt having one. Andrew, would you be keen for one too for the 34? =D If so i would need your car or at least access to its engine bay. =D =D
ive got a home-made heat-shield atm, i would like a full cai box, but money is a bit scarce atm (pooling all of it towards re-build), so maybe later on
hopefully he's going to sell the oil cooler to me. Nah, the pfc isnt hooked up yet. He got george at gt autosound to install it today along with a fuel pump apparently, we were there yesterday to get a hole cut in the engine bay for the fmic and he was talking bout his appointment. Although, I dont know why he's getting/got the pfc installed though because 1/its plug and play which means its basically not hand to install even my sister can do it 2/ it would more than likely be running in limp mode until it can be tuned properly which he's getting done tomorrow at bw.
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
    • Glad it eventually came out Duncan!   I believe that might be 040. 044 is the inline pump, so has screw fittings in and out. 040 is more just drop it in fuel and the bottom is "open" (mesh) from my memory
    • well mate, while I hear your pain, turns out I don't feel it this time! Must have been a bastard of a job crammed into the boot The tank was very empty (probably pumped out, not dropped and drained because there were some fumes still) and in very good condition internally. I'm sure he never ran e85 in it I don't know what the hell Nissan's fuel tank engineers were thinking about their clipping system, this hanger was really hard to get moving but came out in the end All looks very good (as I'm starting to hopefully expect) and Matty was right it is an 023 (044) bosch which should be plenty for the injectors and turbo
    • Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8pm. Supp Regs: TBC Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid  AASA General Speed licence or (Day license is $35.00 via the AASA Website) MA Licenses are no longer accepted by AASA https://aasa.com.au/ A helmet, long sleeve clothing and it is reccomended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs Above. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Entry Link >> https://www.sauvic.com.au/entry/deca/20250208 Entry List: 1. Martin Sullivan 2. Richard Hicks 3. Warren Clark 4. Luca Stamatescu 5. Tony Buckland 6. Min Chan 7.  8.  9. 10.  11. 12.   13. 14 15.  16.  17.  18.  19. 20.  21.  22.  23.  24.  25. 26.    Reserve list 1.  2.
