ive got a home-made heat-shield atm, i would like a full cai box, but money is a bit scarce atm (pooling all of it towards re-build), so maybe later on
thats understandable. If your keen then i would just need money for the materials, i aint going to make a profit of you sam. :chairshot :lock:
  • Replies 6k
Posted Images
it should be. Wish i know how to do real life road tuning of the pfc since he has the hand controller. He wants me to attend and film the dyno tune tomorrow then on friday duc's r34 is getting dyno tuned at the same place and i think he wanted me there too. =S
cool, sounds like you should be busy with the dyno-tuning, i guess you cuold pick up some info on how the tuning is done by watching.
and apply it to road tuning. Im definately going that option once i get my pfc. I remember fiddling with dan's when he got his fitted and tuned. hehehe
Hey Duc, think i could be keen on one of those CAI boxs! How much do you think?
i wouldnt have a clue atm. Depends on how much materials cost - metal/steel/aliminium what is used can be a it pricey last i looked. Im sure i can make them for less than the $130 odd there going for atm. Cant rememeber if will's used bolts or rivets. But i will make one and then go from there.
Yeh no worries thought of getting one for a while now, let me know when available, that would be grande!!
surfing drift related sites and stumbled across this. I love soarers even though its a toyota but this one looks so damn nice not to mention the fact that it has a rb26 conversion. =O
look at that vented bonnet. the vents makes up most of the bonnet.
love the rims
the way the cooler is mounted seems to be very popular with the drift crowd.
thats one tough looking soarer, someones spent big on that one...
Yeah, but why the RB26? Don't get me wrong i love em, but a 2JZGTE would have bolted in MUCH easier, or a 1.5JZGTE (2JZGE block with the 1JZGTE head) is a bloody good setup too, either is not to be sneezed at and with the money saved from a full conversion like that... ah well.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
