maybe the way the power delivery/rev limit? (engine design)
there must be a reason 2jzgte never been used in JGTC while rb26dett GTR win more than any other engine equiped car.
True, the RB is more of a rev-happy race engine, the 2JZ is a hi-po street engine, for a street driven car extra displacement is nice (hence the run on RB30 conv. atm).
  • Replies 6k
Posted Images
I've picked my self up a VG30DET BB turbo with plans to get it highflowed by gcg later on down the track. Anything over 250rwkw I'd be happy with. :(
For now I will be bolting it on with an adj. FPR (maybe injectors depends on $$) to see what she gets.
I'm expecting around 210rwkw peak some where around 5500rpm. ;)
Unfortunately I can't spend money on the highflow at the moment as I need to get the suspension and diff sorted.
The subframe bushes are nackered as is the diff, it now some times breaks out in to a single spinner when jumping on the gas in second, if it doesn't do that it breaks out in to a nasty axle tramp due to the stuffed subframe bushes. :(
do you know how much one is looking at to get a stock Skyline turbo high-flowed Joel?
My Neo turbo also has the plastic impeller - I wonder what the cost would be to change it to a steel one?
It comes down to you get what you pay for. As usual. :(
A cheap bush style highflow is around the 1k mark.
A BB core highflow is always up around 2k. GCG charge around $1900.
GCG are fairly well proven to highflow a turbo that is reliable and doesn't pop, I'll spend my money with them.
I could do the GT30/35 external gate thing but honestly big gates hanging out the engine bay really make me paranoid.
Sambo, Its making 175rwkw at 4400rpm then peaks up to 176rwkw (wow) by 4800rpm then drops to 176rwkw by 4950rpm then tails off to ~130rwkw or something by 6000rpm.
The stock rb20det turbo is waaay to small for the rb30.
It peaks to 12psi as soon as boost is made then quickly tails off to 9psi, this is on the stock actuator pressure. So the peak figure is made on 9psi, not too bad for a little rb20det turbo. ;)
The Rb20DET needed 15psi to make 164rwkw so it goes to show how much better the rb25 heads flow. :(
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
