  • Replies 6k
Posted Images
not bad. spent friday and this morning painting, thats about it. took the sil80 for a drive after the panels were painted and also lose it around a corner - having said that, i did take it at 5000rpm in 2nd gear. was showing how the car handled to a wrx driver who lived in the area. hehehe
yourself? how was your weekend and what have you good planned, if any, for tomorrow?
hehe, did you know the WRX driver? hope you didnt lose it too bad? im probably not doing much tomorrow, probably sleep in.. ususally id go driving, i could go for a bit of a drive, if i dont stop... but i cant afford petrol either :lol: oh well
yeah wrx drivers was my brothers friends older brother - if that made sense. he shitted his jax and do did i, wasnt expecting it to do what it did. yes, petrol is insanly expensive atm. ~$1.25 ish for unleaded. now its becoming a joke.
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
