SA Wasteland?
MM2death
 Share
  • Replies 6k
Posted Images
ugh. coz my dad is italian... and both hes parents migrated to here..... and then had him here. so he is full blooded italian... was jst born here as opposed to in italy.
hence giving me half wog...
um is italian wog?? it's a serious question
(this could be one of my blonde moments)
R31turbo,
I'm doing DB2... if its anything like db1, db2 will suck. :P
No cp2a for me.. Already done, DN. :P
I've got a couple little bits to tidy up then I'm all done.
I've seen you (didn't know it was you then) in the past around car park 2. :(
Pokie...
Blood lines pokie, blood lines. :)
yes Italian is wog.. Some also consider european to be wog.
ha db1 wasnt too bad i got credit but db2 is harder ... programming related sql cmbined with c -- i did it last yr and left a comma orsumthing in my program and it stuffed it all up as she just runs it doesnt look at code so i dropped out. as for cp2a i did cp2b and passed it and i have cp2a left!
Edited by r31turbo
trust me, DB2 is not hard at all :P
i think i got C / DN from the exam with 2 night of study
just did the cp2a exam and i fxxk it
lack of pratice= can't get the program compile :P
lucky Mariusz is offering me a supp...
having wog in you. does not make you a non-australian unless you migrated here and are not an australian citizen
But not following AFL and prefering the soccer makes you a WOG :lol: :D
im half wog, i think every one in australia has i little in them :)
We've all heard that about wogs, visit the loo and come back with a little bit of wog in you :lol: :lol: :lol:
Edited by 4door_Sleeper
your bored? at least you like watching AFL i'm stuck with nothing thanks to the AFL being on nearly every channel
so watch the other channels that don't have it :)
or watch SBS, they have the SANFL on :D
AHAHAHAHAHAHAHA
We've all head that about wogs, visit the loo and come back with a little bit of wog in you :lol: :lol: :lol:
Damn I hate that... Straight over my head, maybe i'm tired. lol
What ever it is you must be thinking of the southerner's and or the sicilians. heh :(
 Share
    • hello everyone, an RB26, or RB25 project in the medium long term. I don't know much about this engine or turbo engines in general, I'm here to understand and gain knowledge. I have specific objectives for a project
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
