  • Replies 6k
Posted Images
id go with whatever gives me the most torque and if im not wrong the 25/30 comes 1st in this department followed by the 25det.
is that turbotech bleedvalve your using the same one as what is/was being sold on these forums? they work an absolute treat. alot better then my ebc, suprisingly.
yeah prob 25/30 but i love the gtr engine torques good but i still want ti to rev out just a little bit... not like a rb30et.
anyways yeah the turbotech it is works a treat
The RB30 does rev (refer to Bu5ters) BUT you need to run a nice big turbo and nice manifold otherwise you will pretty much always make your peak power between 5000-5500rpm. :woot:
Sky30's is a prime example of this. Huge GT35R turbo yet it still only makes its peak around 5500rpm, he dropped 260duration cams in it and made ZERO difference to where peak power is made. An exhaust manifold that can handle the flow (rather than the stock log item) is needed, sure you can dial in more boost to make more power but the peak rpm power is only going to become shorter and shorter.
Have any of you seen silloute88's 3rd gear burnouts? If that aint reving what is... :thanks:
That is making slightly approx 230rwkw I think it was on 12psi.. Would have to double check that, he said it pulls ard all the way to 7500rpm.
BUT he is running a nice turbo and manifold setup.
Then if you consider flicking it past 7000-7500rpm you want to make sure you have a proengines oil pump drive crank collar fitted and possibly an ATI balancer.
But this is the same for an r32 RB26 also. If you want to rev it and not break oil pumps you need either the crank collar or an R33 gtr crank.
yeah ur right ive seen 88silos burnouts marks a big part of r31club aswell. lol
im happy to rev up to 7. all in the future the main thing was that i was happy with my result on 1bar and that it could make alot more with boost raised to whatever is safe
Edited by r31turbo
car would weigh 1400 tops as ive been trying to save weight whereva possible... removed hicas + abs + alot of other crap... im trying to get it to 1300 ill have to weigh it
i hold my car in high regard as even though i know r31s arent everyones cup of tea i am an enthusiast and i paid alot for this car over a r33 and over importing and complying a 32gtr.
Edited by r31turbo
Hey thats great to hear
yeah tis good, but theres so much shit wrong with it, got some rust
the interior looks shit as, got no key for it :P , needs new shockers
needs all windows replaced, coz they've all got yellow paint on em
probably has alot more wrong with it but yeah, i'm gonna have no
money left :
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
    • I'd be looking at the mentioned EFR kit, room to turn it up if decide on e85 (which we know you will) and be super responsive and fun on the street. OR https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/?srsltid=AfmBOorrJa2S76JR5ekXprxBOtU44a1UProbe64YaiVi9zTVp1Lj814w And add whooshy noise for extra fun C5 corvette prices are coming down locally here and a mate has a manual one and is a heap of fun on the street and track.
