  • Replies 6k
Posted Images
ahh how was the clipsal?? i've never been :P
Stomach Wrenching and damn fast! Quite a bit quicker than any of our cruises ive ever been on.. Id love to get a hot lap in my car (maybe with some slicks) and then a hot lap in a v8 to compare differences!!!!... Ahhh one can only dream!! :sorcerer:
yeah tis good, but theres so much shit wrong with it, got some rust
the interior looks shit as, got no key for it :P , needs new shockers
needs all windows replaced, coz they've all got yellow paint on em
probably has alot more wrong with it but yeah, i'm gonna have no
money left :
What's the story behind your car, I've heard bits and peices about but I haven't heard how you came about buying it.
Took my toy out for a drive for the first time since the midnight cruise some time back..... WOW.... Still feeling the adrenaline!...... Dont have any traction in 1st 2nd or 3rd which is a bit worrying but the good thing about a line is you just take your foot off the pedal and correct the steering a bit and it snaps rite back in line. (that is if you dont want to hold the slide heheheheheheh)....
Anyone know if AIR is fixed and ready to run yet or do we still have to do the dodgy on the street?
Must be costing big bickies to have the track just sitting there not being used and not bringing in any money (ie the drags must bring in a couple of grand minumum each weekend)...... is it just the timer board that they are fixing or is there a bit more to it?
I believe they are resurfacing the back section, because i also believe they might wanna hold some other events such as Grip Racing and of course Drift(because that brings in more money than anything) will be good to actually have other forms of racing there(again).
They have actually been needing to fix up the whole track for a few years now...........just look at it!! But better to do it now than later!! :(
Edited by Deluxe
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
