i just changed my avatar pic vange, what is it your having trouble with? it took me a while to get it working
i choose the pic from my comp, i did a totaly diff pic..i chose a pic of a monkey, and the 1 i got now comes up...all blured...
  • Replies 6k
Posted Images
hhmm, Vange..... you got a damn good 'bod (if that is indeed you all sun-tanned in the avatar pic) is all I'll say :teehee::O
On a side note, your previous avatar picture, going back a few months, with the front end of your white R33, looked TOO MUCH like a Lancer. Why is it that on some angles, white R33's from the front look like Lancers?
i was just thinking b4....we had the problem that we didnt know when we c another skyline if they r on sau or not...well i have that problem lol
instead of stickers, how about a special 'signal' so we know..
in most cases, we c the other car travelling in the opposite direction, so how about when we c other lines, we flash our breaks a few times, and if they do the same, u know they r sau :)
also if they r behind u, flash ur breaks, n respond with a quick flash of the highbeams. same would work when crossing paths at an intersection.
any1 else think this is a good idea, or should i just shut up?
we discussed this a while ago....doing the nod, 1 finger off the steering wheel etc...too damn hard.
Everytime i see some other knob in a jdm car out on the road and im in my line, they are always looking at me sly to see what im driving for some reason, or they have a mate with them that is breaking his neck to have a look...what the f**k is so special about other peoples cars?? Especially my beat up wreck??
I undertand people seeing others they know, but racing, and trying to "impress" me with doing skiddies on the road aint funny at all....it just draws attention to me, which isnt cool if i get defected!
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
