  • Replies 6k
Posted Images
i looked down my driveway and what do i see...a nice stream of green liquid! yayyy new water pump! no car for the weekend...mechanic said $300 to fix it. dam these thing always happen on fridays so u dont have the car all weekend. :)
I would be very happy with it only being $300 to fix.
Its quite a big job replacing the waterpumps on these RB's.
You require coolant... The water pump, there's almost $150 in parts.
Then you have to remove the radiator, all fan belts, harmonic balancer, timing belt, remove the water pump replace it then all those bits go back on again. $300 is a very good price and who ever it is is definitely looking after you. :)
anyone know the legalities of driving on prescription narcotics? :P ie insurance, police/courts, etc
on Endone now for a while..... man it makes a huge difference to the knee pain, its amazing :P whats more it aint giving off the fuzzy-head pill-syndrome,so thats good.
oi - how about this damn avatar???!! wicked, found it on ebay
got a drive in a SRT8 Jeep. Its only slightly slower than the Porsche Cayenne Turbo S. It does a 5.1 0-100, not bad for a 2 tone car :) It's now the fastest car that we sell, Its even faster that the lighter 300C SRT8
When you put your foot down there is no wheel spin it just launches off and get really fast quickly. And it sounds fantastic with its standard 3" twin exhausts
But then again for 85K you can get a fast GTR that doesn't need to be refuelled every few Km's
You tube have a few decent vids of the SRT8 Jeep.
Interesting... They appear to be running High 13's. :S
Unsure if they are stock, sounds stock. Apparently the ecu also limits throttle until a few kays have been pushed up on it.. Not sure how true that is.
lol...
I came across a snip from a bathurst vid I chopped 2years or so ago.
Awesome little clip this... Pure Power down the straight.
http://videos.streetfire.net/search/Skylin...63462250d20.htm
Whatever that chasing car was, it got owned yours truely!
    • Updating results from our ATR43SS-1 turbo in T3 .63, OEM bolt dump pattern. Not a big number but pretty sweet for a stock Rb20det. Car's managed to pull 220rwkws at 20psi, perfect boost control internally gated with EBC and excellent mid top end power band as they usually skydive after 5.5K. Usual bolt on supporting mods and inlet plenum and factory location exhaust manifold. Pump 98 fuel was used (Ron 93).
    • Yeah, well, it's not as though anyone is ever going to buy one of those noisy f**kers and put it into a new installation when there are better pumps that are near silent for less money from Ti.
    • I'd suggest having the engine builder listen to it, especially if they assembled it, and minimise how much you run it in the meantime. It may have a serious issue like a big end bearing from the description and I assume the rebuild was not cheap
    • Quite right, typing without checking, it is an 023 which was effectively the replacement for 040 (not that I could find either of them on the Bosch motorsport AU site), and it has a mesh inlet at the bottom of the pump rather than a separate filter
    • Hmm. I should have thought of the clutch bleeding issue. It should be #1 thought for "can't select gears". As to "sounds like the top".....have you actually gone out with the stethoscope and tried to pin it down any more than that? And, buy or borrow a timing light, and set the timing properly.
