  • Replies 6k
Posted Images
I don't mean to be negative but it looks abit photoshoped around the front indicator on the drivers side It has a bit of shading matching the bumper around the passanger side.
just my 2c
would be cool having a 4 door GTR
Edited by Whiplash
that aint a photochop. its a conversion if you didnt spot it already - refer to the interior pic. its got a gtt passenger seat as well as gtt speedo dash. rb26 rwd.
Edited by Nozila
found this rather interesting
http://www.automotiveforums.com/vbulletin/t231647.html
a flash back to the group A days when the R32 GT-R made an entrance. i wasn't really old enough to appreciate these cars back then, but i did go with my dad to the mallala round.
    • Yeah, well, it's not as though anyone is ever going to buy one of those noisy f**kers and put it into a new installation when there are better pumps that are near silent for less money from Ti.
    • I'd suggest having the engine builder listen to it, especially if they assembled it, and minimise how much you run it in the meantime. It may have a serious issue like a big end bearing from the description and I assume the rebuild was not cheap
    • Quite right, typing without checking, it is an 023 which was effectively the replacement for 040 (not that I could find either of them on the Bosch motorsport AU site), and it has a mesh inlet at the bottom of the pump rather than a separate filter
    • Hmm. I should have thought of the clutch bleeding issue. It should be #1 thought for "can't select gears". As to "sounds like the top".....have you actually gone out with the stethoscope and tried to pin it down any more than that? And, buy or borrow a timing light, and set the timing properly.
    • I donโ€™t really have any ideas how to set the timing on the CAS ๐Ÿ˜‚, sounds like the top, sounds like it maybe misfiring as well as ticking,ย  got the box sorted ๐Ÿ˜Œ, must of been a air bubble on the clutch side
ร—
ร—
