Did they say why they couldn't remove the rear left wheel?
Lock nut? Spinning stud?
Either way you should be able to spin the wheel around and see with a torch how much meat is left on the pad. Looking at the opposite wheel will give you a good indication how much meat is left on the left.
The skylines brakes wear fairly evenly due to being 4pots up the fronts and 2 pots at the rear. So the inner doesn't wear early like that of the usual clamp type pos brakes.
I wouldn't be concerned.
Have you bought it yet?
Get under the car and check the chassis rails for damage.
  • Replies 6k
Posted Images
yup :wave:
hey guys i need a little advice, im purchasing the car on friday but there is a small problem and that is the RAA couldnt get the rear left wheel off the car to check the brakes on that rotor.
Got any advice, should this sort of thing hold me up greatly?
why dont you take it to a workshop that specialises in skylines? RAA is pointless when it comes to these checks, they only good for when your car breaks down and needs a tow.
yup :wave:
wtf? Id be wondering why they would not be able to take a wheel off...cbf, or something wrong?
I'm not too fond of the RAA inspections.
I bought a VS 5ltr 5speed some 7years ago, had it RAA inspected and they missed an obvious inlet manifold water leak and loose engine mount that had the exhaust hitting the body under acceleration. :wave:
The inlet manifold leak was a real pain in the arse to get fixed too.. They had the car for 3 weeks and racked up almost 70km's, I got it back and the clutch felt all spongy like they had been slipping it. :)
From there that car was down hill... Such a damn unreliable (drivetrain) money pit. Well at least the new owner got a good deal; new diff, gearbox and rear subframe. :O
The RAA said that "several of the wheel nuts were damaged, so unable to complete brake check."
The guy did a very thorough report and they do check everything on their check list. I mean id want a full refund of the 200 dollars i spent to get myself some peace of mind before buyin the car.
I'm not worried about the brake pad, Im worried about the wheel coming off, I think im going to tell him that I'm not coming to pick up the car until he can get that wheel off and then refit it with new nuts. without breaking his nuts is the key, but i guess im the one with the cash anyway.
Edited by SAZilla
so he has to brake a nut to get the broken nuts off :dry: how do nuts get broken...id ask for explanation.
he is thorough, but did they do a compression check?
yes, came up with 5 percent within eachother,
is that good?
@cubes, private sale bud
my mate said if the problem is that serious ill have to spend quite a bit to get the thread welded back onto the rotor or whatever to repair the damage done by the nuts. only problem me and my mate -who knows quite a bit about turbo vehicles- picked up was just a scratch on the door that could be buffed out and thats it. the car was beautiful on the test drive.
Edited by SAZilla
Update: I rang mike said to him id pick up the car on monday definitely if that wheel was removed then refitted succesfully, he agreed and is getting a mechanic to do it. so thats sorted...
so yer 5 percent is what the RAA said, I gather thats 5 percent loss or 5 percent difference between all cylinders.
5% variation is a fair amount but I'd say its most likely <5% which is considered ok.
The chances of a car thats 10yrs old having near perfect compression ratio is slim.
Please cheak the head lights when you pick it up... I was excited and forgot to... Turned the head lights on and then had to hunt around for H3C bulbs that absolutely no one had apart from autobarn that was closed. :dry:
yep the lights in her have been changed already, all but this rear wheel bullshit is fine. all the suspension and undercarriage is fine aswell but he couldnt check out that disk and that wheel and anything behind it. i rang the guy and told him to fix it for me today so i can pick up car on monday. so hopefully all goes well
easy
when i go to pick up the car, with my mate, I will say:
"fixed that wheel?, I want to just check the brake pads and the rotor before I give you the cash."
then ill check it, find that its all good, and then bang im done.
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
