that looks killer man. Who'd you go through for the importing?
I've imported it myself, was introduced to an Adelaide bloke, who works for a dealer over there, while he was back here for Christmas and went from there. Hes actually part owner of Kansai Automotive, and his family is heavily involved with the car scene here in Adealide. Not sure if i should give out his contact details as hes basically in direct competition to SAU sponsors, but if anyone wants help importing a car by themselfs let me know and i should be able to guide you along nicely =D
and thanks everyone else, hopefuly i'll be able to go for my first cruise and meet lots more of you on the 28th/29 of this month =)
  • Replies 6k
Posted Images
doh, always thought it was safer to tune on a low-30deg day.
Not sure if Shaun shares the same view. Its only an observation I've made through my own multiple tunes, friends cars and how mine reacted on the stock ecu when pushing 1bar. Consistently the same. Cold Tune FTW, hot day tune FTL.
BF2.. I haven't been on much as the computer as crapped it. :spank:
Spending too much on the car as of late so the computer can hold off. :3some:
Thats HAWT!!! Fishpaste :3some:
How long did it take to come over??
I might be looking at importing one myself, as cant really find anything I like here already :spank:
It was purchased late in January (but had already been passed in at auction once), so from when the car was first found to when it arrived was less than 3 months, and it'll be just over 3 months when its on the road =)
if your looking for someone to help you find one, let me know and i'll get you his contact details.. in the middle of writing up a big "how to import guide" ATM so that may also help you out =)
does importing a rally/race only car cost less or does it only cost less because you dont have to comply it
like im thinking a full drift spec ceffy
yeah madaz, if you take a look at the import101.com import calculator (you have to sign up to get access to it) you can see that all the SEVS and rego and other related costs to the whole getting it on the road bit are $0. so that is where you get the savings from, but from memory you do have to have a CAMS licence of some paticular type to import under race and rally.
I know where there is a cheapish Ceffy and its got all the set up :3some:
Let me know if you want any details
Thanks
Im looking at all avenues at the moment,will let you know if im really serious about importing one my self
Thats not bad 3 month turn around
what was even more amazing was that i was having tea with the dealer here in adelaide on a tuesday (as hes originally from here and was back in adealide for christmas) and that friday he was ringing me to get the go ahead for the car!!!
so its almost literaly 3 months from the decision to buy the skyline to getting it =)
not sure cubes he said he would swap it with gtst but gtst have hicas too so im not sure whats different about mine
but he was willing me me to come and see him tomorrow to sort it out
can highly reccomend ISC on after sales service and i wasnt the orriginal purchaser very good buisness ethics
I know you might all call me a geek for this but I don't care! :thumbsup: Just came back from dinner with Avery Brooks (Captain Sisko) and Barry Jenner (Admiral Ross) from Star Trek: DS9. Both awesome fellas, had a great night, just had to share... and yes, I'm a trekkie!!! :santa:
Edited by heslo
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
