SA Wasteland?
MM2death
 Share
  • Replies 6k
Posted Images
hmmm, just test drove the 350 down at lake side nissan.
*looks at bank statement.*
i wonder how much i can sell a kidney for...
:huh: I thought you were getting a GTR!!!
lol, that was the plan.
but the Z is sooooooooooo nice to drive.
bah, its a tough decision.
its so smooth, the shift is nice and quick, the brakes are incredible, the steering response is something else entirely...
and its a new car, 5 years of warranty, its only done 7,000 kays, doesnt have the bumps, squeaks and rattles and inevitable engine rebuild coming up that a nearly 20 year old GTR would have...
Edited by scandyflick
Yes I can't wait....
Paul.. have you seen Troy's vids? Stock rb20det td06-20g pushing 260rwkw.
PI is a damn quick track compared to our little Mallala; majority 4th 5th gear 180km/h corners, 240km/h down the straights. :huh:
The car was a little nervous as you can see. Suspected blow shock. He recent sent it in to a wall of tyres as it spun on him at 200km/h when jumping on the brakes. I'm guessing he'll get its problems sorted. :S
PI is a damn quick track compared to our little Mallala; majority 4th 5th gear 180km/h corners. :huh:
Going there this weekend to help my mate with his Saloon Car! Yeh he says 5th thru turn 1, just holding onto the taxi! we leave Friday arvo and come back Sunday night.........sometime!
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
