SA Wasteland?
MM2death
 Share
  • Replies 6k
Posted Images
My message, and a Number to help ya :)
Hi Jeff,
I'm wondering if you can clarify something for me. Are you able to do a remap on an R33 GTS-t Series 1? My car is presently running quite rich (I think) as I put in new spark plugs just over 3 weeks ago when I bought the car, and it feels as if they have fouled already (slight miss in low revs). So I would like to get the car on the dyno and tuned for its current state. Presently I have a cat-back 3.5" exhaust, Mushroom filter and stock boost. I would like to get a turbotechbleed valve, and have the boost set at 10PSI and a tune to suit. Can you tune my 33 to suit these mods? Im looking for a good safe tune that will give me good results for every day driving.
Cheers
Lee
Hi Lee,
Sorry for the late reply, i must have missed your message before.
I can remap the R33 although it works out a little more expensive than most of the other nissans.
Please give me a call and i can fill you in on all the details.
0434 637 357
Cheers -Jeff
Yeah it was pretty cold here this morning too
seeing the pic of the ice on grass reminds me of when i was younger
every morning b4 school i use to outside and slide on the ice hehe
(i had shoes on), ahh the good ol days :D
Damn it was cold last night! Got to work today down in Cudlee Creek, turned on a water tap and no water would come out the hose, the water inside had frozen!!! :D
lol, cubes is a sook. sleep is for the weak!
"Weak sauce" is the term..I think! :D
you should read it :D
i couldn't imagine doing that to a guy :)
Eeewwwww :D
Damn it was cold last night! Got to work today down in Cudlee Creek, turned on a water tap and no water would come out the hose, the water inside had frozen!!! :)
LOL thats cold!
You know, how I know it's cold....... ;)
Friend of mine works for GPA engineering. Local consulting firm that deals quite a bit with Santos, SA Water, Zinifex etc. Based locally with a fair bit of site work. Could be another good option, as sometimes the big companies you listed tend to forget you're a person, and think you are just a cheap resource ;)
Yeah, one of my mates is with GPA too (just stareted this yr), Worleys too. Some at Santos ( I worked there too for 3 months over summer), Adelaide Brighton & BHP.
I'm actually a bit worried about becoming a 'number' with the big boys. :)
But at the same time I don't wanna go into consulting I want real engineering work not just purely design. (I got an offer from KBR but i think ill turn it down just coz i dont see myself sitting in an office all the time doing design stuff)
lol im sure there out there bit off topic but type in wrx tow or wrx crash (cbf finding too drunk atm) and theres a bug eye wrx in the states bein towed and numb nuts forgot to turn it too on so steering lock kicked in and bang towed into a tree its so sad but bein yanks its funny, and also all the commo one wheeler burnouts turnin into crashes lol
wooooooooooo a family friend had a baby today
it's a girl yaaaaaaaaaay i can finally spoil a girl with care bears
and strawberry shortcake stuff hehe wooooooo :D;):P
ok i just suck at it then, but maybe its cos im on a laptop, no actual mouse. Im unco and cant co-ordinate the touchpad thingo on the laptop. Yay for 3.8 metres hahaha
 Share
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
    • Mmmm. Perhaps more correctly stated that the one turbo doesn't actually force air back down the throat of the other. All it does, and all it has to do, is be pumping a little harder than the other turbo (which is an effect of how the turbos are getting driven by the exhaust and inherent resistance to output air flow that each turbo sees up to the merge). If the turbo that is not flowing quite as much then nudges the stall line (because it gets pushed there by the higher flowing one stealing the limelight and moving its own operating point further from the stall line), then you get the behaviour described by Josh. There is no need for air to move backwards in any way. It just needs to be less air moving forwards than is required to stay to the right of the surge line.
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
    • Yeah sure, which messenger app is it?
    • would you like to be added to the messenger group?
