  • Replies 6k
Posted Images
Cheers for that cubes!
Do you do this in your shed with the car on Jack stands, or is a hoist really more necessary?
Also, where can you get a flywheel machined southern suburbs, and any idea of cost?
Cheers!
I've only done one on the ground with jack stands and found it quite easy.
The old man used to have a pit in the house he recently sold; doing a gearbox in the pit was easy to get to bolts etc BUT getting the thing up and down was a pain in the arse as I had no gearbox lift. :D
No idea of where to get a flywheel machined down south, I used to do it down at a mates girlfriends dads mechanics shop at Aldinga when I was younger. I'll have to look soon though as Im up for another clutch soon. :S
Last time I had my flywheel machined the machinist did it as it was also being balanced for the new motor.
Ohhhh noooo scandyflick!!
What happened to the soara?
its still available afaik.
but using the money to move out will be infinitely better for my sanity.
ill have to wait and see though.
:) i'm sooooooooooooo happy today hehe
the lady (Lois) i help out in the op shop asked me today what i'm gonna do
after i've finished me hours there. i said i'd probably continue working there
and she had the biggest smile on her face.
i've only been there just over a month and they already trust me hehe
it's great.
she said it's hard to come by people like me :) (you should all take note of that :))
I tried to do some local volunteer work early last year.
It was a government organisation that helped elderly people get to there doctor's apointments, specialists, etc, etc. So i got all the info and arranged to have a meeting with the manager. And i got there and they laughed at me and said "why would a young person like you want to do that" so i went "ok" then and left.
f**k them if they are gonna laugh at me. Try to do something to help the community.
Oh wow thats cool!
Where are you moving too? Hopefully with a mate to share the cost??
You think adelaide is expensive lo!!
Volunteer Firefighter.
Then you can crack the firemans hose joke with the ladies. lol
haha Fireman are hawt!! :)
Oh wow thats cool!
yeah, im moving in with a girl i work with,
out in unley or summink, its a shoebox compared to what im used to, cheap though, only $170 a fortnight.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
