  • Replies 6k
Posted Images
Sept 10th at Boostworkx
Fit cam gear (supplying group buy Aerospeed item)
Install Oil filter relocation kit (supplying Greddy item)
Oil change (z145 oil filter + Motul Turbolite 4100 oil)
Attessa Flush with genuine quality fluid
Retune inc remove and refit tailshaft (safc / sitc / 15-16psi not sure yet)
Install braided lines and bleed system (supplying Maltech lines and Castrol super response dot4 fluid)
Install Front rotors and pads (supplying Dba slotted rotors and Bendix advance pads)
got a good quote, so Im happy with that.
cant wait
looking to "feel" around 200awkw I suppose.
nice tangles. 200awkw is ballsy.
lol, cheers :laughing-smiley-014:
blue-ballsy ?
hahaahah
yeh, at the end of the day, I bought the Stagea 2 years ago with an overall budget of 30k in mind (incl 18k for car) and a setup safe for 200awkw. which is what it'll be. brakes/suspn/engine all "tuned / setup" for the HP output.
only thing missing would be the auto tranny to be serviced + shift kit; all in good time tho.
Brendan - sorry i didn't catch up with you this week i been not well since Wednesday i thought i was going to catch up with you on fri but got worse then i couldn't even talk had to get my mum to ring my boss to say i wasn't going to work ... is there an emotion for how embarrassing ;)
anyways im feeling a little better now so i imagine i will be able to catch up this coming week
well im back @ work i finish @ 3:30 Brendan i will run by the city on my way home :cheers: but where excactly will i be running when i hit north tce if i ring you are you able to meet me on the street jump in the car run around the block and drop you back :P or something like that so i dont have to get a park
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
