  • Replies 6k
Posted Images
I can't find anything to say that it exists in SA.
I can fine the bills for both houses of parliament, but the act they sought to amend in 2005 makes no mention of double demerit points (I've checked all references to "demerit" in the text) in the 4/2007 version.
I really want to know for sure - I guess even if it is a myth, it will probably reduce people committing offences, which isn't a bad thing.
I remember seeing it on the news ages ago, before i went out (thing it was a Saturday night) and i actually got pulled over and the cop confirmed it...
I've certainly heard lots about it too, but I've heard lots about the Loch Ness monster if you know what I mean.
I'm looking for some hard evidence, which would hopefully also state what offences these double demerit points can be applied for.
Surely the elbow out the window thing isn't included - or is it? Would you really lose half your licence for that on a long weekend?
If anyone has anything - video clips, legislation, pdfs, links -anything - I'd love to see it.
just out of curiousity... if your sitting at home on a day like this wtf u thinking?
My excuse is im off work with a broken ankle that is almost fully heald but sat night i blew my custom inlet plenum appart running unlinited boost so now im stuck here!!!
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
