  • Replies 6k
Posted Images
Just a reminder to blank out no plates on photos on hear. A guy off another forum had the specs of his 300ZX listed up in a thread with pictures of the car.
Regency has contacted the owner and he now has to go down for a check on the vehicle. They got his contact details from the number plates on the vehicle.
seems like they are getting desperate if they are going through forums to catch people out
** I heard this second hand from someone i trust so i can't guarantee 100% that it is correct**
Edited by Whiplash
sounds like bs to me lol. If they rang me it would be pretty simple....my car isnt going, my car is a show car, my car is kept registered for race class purposes its gets trailored everywhere lol. If that actually happened that dude with the 300zx is the dumbest dude ever lol.
I always thought it was a load of shit when ppl told me bout cops looking on car forums for stuff like that. they should be out catching these noobs that are stealing cars and beating these old ppl. What's the world comming to!!
*rubs fingers together in a manner that indicates money.*
the 'hoons' are worth more money then some punk who knocks off a car and your old lady every now and then.
easier to catch, and theyre worth more.
fairly simple stuff really.
The bloke off NS.com had put a VG30dett in his S13, it's a very professonal looking job. He only finished it a couple of weeks ago and has only driven it on the road 2 of 3 time. He had post pictures of the conversion on NS.com when he finished the conversion (there must have been his plates in the pictures). Last week he received a letter and i qoute:
as some of u may know i have recently completed my silvs i received a letter last week stating that they had photographic evidence which was obtained from the internet "my car has only appeared on ns forums" they stated that i had made mods and that they have frozen my registration and i cannot drive my car until i present my car for inspection.
i don't think he has been doing silly stuff as i think it's a fresh engine. I'll see if i can find some pictures of the conversion.
NS.com Forum Topic: TRANSPORT SA WARNING
Edited by D_stirls
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
