  • Replies 6k
Posted Images
all i have to say is nothing is a bolt on kit. It took most of the afternoon - we had to run around for food/misc duties. Performance? I wouldnt have a clue, you would have to ask will that but i recall him saying is that it doesnt make a difference which i then replied its just a safety modification.
btw do you remember the name of the filler that you were going to recommend for me to use on the car - its all sanded back now. Just need to fill some dents and its ready for primer. yipee
btw will is definately serious bout upping the performance on his car sam. When i was there i discovered his pfc, fmic - which we installed and oil cooler. Didnt see any aftermarket turbs though. His getting a tune tomorrow morning supposively @ boost worx.
yeah FMICs don't improve performance - if anything they degrade performance slightly, as they make cars a little more laggy (due to the car having to pressurise a larger volume before making boost). But, they are vital if you want to up boost, and they lower the intake charge temperature to help prevent pinging.
sam, do u want a cai box for your 33? Im going to get will's cai box - the one he bought of max, and fabricate it for 33's and 32's. I inspected it when we had to remove the air filter and its looks quite easy to do as long as i can get the materials. So are you keen?
so you hooked up the pfc too? whats going to happen with the oil cooler, is he gonna sell it or hook it up?
this is the exact cai box will has. I dont know if it does any good would it wouldnt hurt having one. Andrew, would you be keen for one too for the 34? =D If so i would need your car or at least access to its engine bay. =D =D
ive got a home-made heat-shield atm, i would like a full cai box, but money is a bit scarce atm (pooling all of it towards re-build), so maybe later on
hopefully he's going to sell the oil cooler to me. Nah, the pfc isnt hooked up yet. He got george at gt autosound to install it today along with a fuel pump apparently, we were there yesterday to get a hole cut in the engine bay for the fmic and he was talking bout his appointment. Although, I dont know why he's getting/got the pfc installed though because 1/its plug and play which means its basically not hand to install even my sister can do it 2/ it would more than likely be running in limp mode until it can be tuned properly which he's getting done tomorrow at bw.
Guest
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
    • Just chuck in an ECU, Injectors and a pair of direct fit low mount turbos, that should use to the top of your budget and give it a nice kick along. Also, don't do anything unless you don't need the car daily....if it does blow and you get another 10k bill just to get back to where it is now would you be able to come up with the cash or will it sit for 2 years like most GTRs....
    • Thank you 🙏 I'm patient, which is good, considering the limited budget (for now) more so trying to understand where to begin the journey and you and the others have been good with that, appreciate everyone for their input 🫡
    • $5-10k isn't much for reliability if your looking at more power for a RB Me, with that much money currently on hand,  I would only look at things to suit future mods, as stated, a fuel pump and ecu would be my first point of call, as well as getting the injectors cleaned and tested, maybe even replace all the coolant hoses After a little time with the tuner, they should be able to tell you how your car is running in relation to things like your ignition, cooling, and other stuff that will be picked up when it has had a few runs up on the dyno and some logs to look at Basically, get everything sorted for reliability before you start leaning on a 30 year old engine Good luck with the one and only true Godzilla, enjoy Note: for your birthday presents, ask your family and friends for lottery tickets, a 32 GTR can cost "all of the money" to make reliable power
