i dont think it would be that hard unless you would rather pay someone else to do it. i painted my calipers myself - piece of cake, and have painted the front of my sil80 myself which sam though was resonable ok - well the one that i though didnt need attention which i was quite happy coming from a spray painter himself.
  • Replies 6k
Posted Images
Be sure to spray the car when it's not cold. :D
or. Hire a heater. :rolleyes:
ive already done that mate. hired a heater and compressor.
i successfully sprayed one front panel and front bar but felt that the others were not how i would have liked it to be. thus why im asking someone if i could borrow a compressor for a few days or else i would have to donate that money to kenndards and the likes. plus now i have a gravity feed spray gun whereas i had a siphon one before. would make life easier since i can now spray bodykits at home, yiipeee.
you're welcome to borrow mine Duc - I just had a look at it - it is only a dodgy el cheapo GMC one, but is brand new - I haven't even fired it up yet.
1500W 2Hp
tank capacity 24L
206L/min tank displacement
117l/min free air displacement
0.8MPa max pressure
these numbers mean nothing to me - maybe they do to you?
thanks andrew much appreciated. they dont mean nothing to me either only the cfm matters, ill ask sam if its sufficient. Again, thanks andrew ill take you up on the offer hopefully. btw why havent u used it yet, impluse buy??
hey duc, when u planning on repainting the silvia panels?
hopefully at the end of this week pending weather. Got some installs/maintenance to do as well so yeah. btw andrew has posted up a list of spec on his air compressor, you thinks thats suffiecent sam or do you need to see it to look at cfm - would give us an excuse to see andrew's car also. =D
you in adelaide/murray atm?
24L tank is a bit too small, you would find yourself constantly running out of air pressure. you would really want a minimum of 50L tank and 3.0HP, to keep air pressure consistantly above 3.0 bar. what spec was the last compressor you borrowed?
im back in murray bridge atm, i help my dad out with his hospital appointment.
i honestly cant remember but just know that it was 12 cfm electric compressor. i think it was 3hp. A wells im just gonna have to hire another one i guess since its my last resort. Just bought rego the other day and its begging to be driven =D coming back to adelaide anytime soon?
i'll probably be back in adelaide this weekend.
you headed to mallala this weekend?
i hope the weather is going to be at least not raining this weekend. Thinking bout touching up the paint on saturday and drifts sunday. I might give the rally a miss this year. well, thats my intentions anyways.
im keen on going to mallala, ill let you know. yeah, hopefully the weather will be like last sunday. im heading down to adelaide tomorrow, more carport work to do :( have you sorted the air-compressor out?
i havent had the chance to sort out the compressor as yet. Probarbly go and look at some today @ kennards or usual place i hired it last time from. Having said that, im not sure if im going to get it though because if its raining on the weekend then theirs no point to it.
Has shaun got the block/heads etc back yet so your car can be put together?
Guest
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
