  • Replies 6k
Posted Images
last week i changed the water pump on my alfa. Put everythin back on. Turned over the ign. Daim doesnt start. Timing was wrong on inlet side :D Needless to say bent 3 valves. Not bad 3 out of 24....
Anyway there goes 1500-2000 bucks. Daim and i was savin up for my powerfc...
hey guys i just had biggest brain wave ever, this would benefit you enrico if your saving up for a power fc.
ok here it goes.
what if we bought a sony explode 2 way 222w amp and replaced it with our factory ecu. would that give us an instant 222rwkws!!!!
even better what if we bridged them..or even bought a 1000w 4way boss audio amp wed have 1000rwkws....!!!!!!!!!!!!
Guest
