  • Replies 6k
Posted Images
id be more than happy to do that. with the previous cruise, thats why i did - went crusing in the hills in the missus celica and worked out what roads were nice and so worth. end result was what we eventually cruised on which everyone seemed to like.
Yeh that was my car, but not too sure if it was me sitting behind the table, Tall with blonde hair?
cant remember, its been some time now but im sure the stand was promoting the products you had in your sig.
rofl @ the looking so sad comment. mines in the shed with a faulty starter motor i suspect. so im going to sort that out before i drive it again plus it ran out of rego the saturday that went by which co-incidently was also when the car started to play up (bad luck and timing i guess).
No i don't have any thing in there yet, prob only go for the Cradle bushes, As i already have Cusco Strut bracing, I might go a Steering bush.
Christian Pickering has had the strut bracing in at the G1 event and claimed it was stiffer than Viagera, and Kelly McKinnon and James Mardle runs his stuff also. The product is made from Aircraft Billet Alluminum and is strong as, and is HEAPS light, can't believe how light some of that stuff is. Did you check it out at Mallala?
upgrade to what chillam? im assuming your talking bout cars btw
no, loyal to the origens of twin cam RB... the 20!
But, goodies included in upgarde:
RB25 series 1 turbo
SAFC2
Remove inlet butterflies on inlet plenum
Fix busted studs on exhuast manifold
Rebuild clutch cylinder
Full Serive and Dyno tune
I cant wait to see the dyno sheet!
I go out for the night and there are hundreds of pages to read!!! you guys are hilarious.
RB25 series 1 turbo
SAFC2
remeber to post the result here with dyno sheet ;)
Guest
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
