  • Replies 6k
Posted Images
was browsing the net (s2ki.com forums) for a friends who's interested in a turbo kit for his s2k and came across this. turbo kit supplied by lovefab
v-tec and turbo :O
price? messly $7k USD cheap considering a Vortech S/C goes for $5k AUD installed + tuned (i think)
Edited by Nozila
Imagine revving that thing to limits like V-Tek should. Damn! It really is a damn shame Honda make a shiat load of FWD's.........Way to keep the yanks happy Honda!
i drove a honda prelude around at work today, i love how the 4WS works on those things!!!
thought id share my current problem with everyone, if you had any ideas to help me out would be appreciated. copy pasted below:
Well, I've had my car off the road for 2 weeks now, basically all of which have been spent at my tuner's shop. The problem:
Start her up and will immediatley run very rough, rpm jumping up and down, missing etc. Leave for about 5 minutes and it will idle smoothly instantaneously, or take for a drive and about 5-10 minutes of driving it will act more normal in terms of idle. BUT then it doesnt have any power under load. It becomes flat, you can hear the turbo spool and a rush of air, but goes no where.
What has been done:
He has replaced all engine sensors, AFM, CAS had it on the dyno. Fuel pump, lins, filter all checked as well and cleaned. It is running lean... very lean, so lean the engine doesnt have enough fuel to operate properly, this is occuring on all cylinders.
Higher temperatures seem to make it better, the longer you run the car for the better it gets, but never close to perfect. He had determind that the problem has to lie either with the ECU, or the wiring into it. He is supremely confident that an after market computer will fix this problem. I have access to R32 ECU and loom, and hence this should also fix the problem, once wired up correctly. I need second, third etc opinions though before i go ahead and spend money, hence this post.
I have just recently had the entire intake side off, inlet butterflies remove and sealed up good and propper. exhuast manifold has been ripped off, studs replaced and put back on with the addition of an r33 turbo. Amoutn other things and a full service. Was running fine until about 4-5 days after, then it got progressivly to ths state. It did this before i had this work done, but on a VERY small level, and 10 minutes of driving would see if going perfectly.
hey stevo! there are no boost leaks or anything?
your problem sounds very similar to one of the guys at work who has a VL turbo. had the exact same symptoms and all, weird idle & no power under boost, the boost guage read 9psi and absolutely no extra power, it was the same as driving an NA one.
It tuned out all of the injectors were blocked up with crap & one injector was faulty. injectors were cleaned out/replaced and it ran good again.
Guest
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
