  • Replies 6k
Posted Images
went on a mini cruise last night with 3 other GTRs, 2 WRXs, and a RX7 S6 to Lobethal and back. Had issues with losing cars in traffic though. Engine was hot and brakes not as reponsive on way home but it sure was fun!
not sure about that one.
i always put BP in my car, execept i ran out last night & the BP was closed so i had to fill up with shell, starting off for the first 5 minutes i took it easy then i went up to about 4500RPM in third and got a knock reading of 75 on the PFC!!! im gonna wait till this tank runs out & im never going to put shell fuel in there again
Sam, Shell don't sell 98 octane fuel in SA, so if your car was tuned using BP Ultimate 98, putting Shell Premium (95 RON) is definitely NOT a good idea with an ECU with no knock control.
To be honest mate, I'd drain it and refill - it might be $60 worth of juice, but how much was that rebuild again? A LOT more.
Oooo, i havent been on a good run for ages! nice weather at night now for it, can actually get out the car and chat without getting drenched.
Also, I'm going for the Microtech to solve my problems, so car should be back at christmas time :(
hope all goes well for ya steve :D
thanks for that info will, i didnt know the shell was only 95RON.
i didnt put much of the shell fuel in there, just enough to get me by. so today i filled it up the rest of the way with BP and its running all good now.
from what ive read the knock reading of 75 isnt too serious, but ive learnt a lesson there.
with that first 4000RPM right before the boost really kicks in, the computer over-richens the air-fuel ratio, not sure why, but thats why it goes all flat. i noticed my car used to back-fire a lot around those RPM, but now it rarely ever backfires
i was originally going to, but i ended up getting it fitted & tuned all in one. i also needed a bosch fuel pump, cos the stock one was running out of puff. i got boostworx do do mine, they did a top job. but i also heard good things about graham west too.
Guest
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
