  • Replies 6k
Posted Images
id go with whatever gives me the most torque and if im not wrong the 25/30 comes 1st in this department followed by the 25det.
is that turbotech bleedvalve your using the same one as what is/was being sold on these forums? they work an absolute treat. alot better then my ebc, suprisingly.
yeah prob 25/30 but i love the gtr engine torques good but i still want ti to rev out just a little bit... not like a rb30et.
anyways yeah the turbotech it is works a treat
The RB30 does rev (refer to Bu5ters) BUT you need to run a nice big turbo and nice manifold otherwise you will pretty much always make your peak power between 5000-5500rpm. :woot:
Sky30's is a prime example of this. Huge GT35R turbo yet it still only makes its peak around 5500rpm, he dropped 260duration cams in it and made ZERO difference to where peak power is made. An exhaust manifold that can handle the flow (rather than the stock log item) is needed, sure you can dial in more boost to make more power but the peak rpm power is only going to become shorter and shorter.
Have any of you seen silloute88's 3rd gear burnouts? If that aint reving what is... :thanks:
That is making slightly approx 230rwkw I think it was on 12psi.. Would have to double check that, he said it pulls ard all the way to 7500rpm.
BUT he is running a nice turbo and manifold setup.
Then if you consider flicking it past 7000-7500rpm you want to make sure you have a proengines oil pump drive crank collar fitted and possibly an ATI balancer.
But this is the same for an r32 RB26 also. If you want to rev it and not break oil pumps you need either the crank collar or an R33 gtr crank.
yeah ur right ive seen 88silos burnouts marks a big part of r31club aswell. lol
im happy to rev up to 7. all in the future the main thing was that i was happy with my result on 1bar and that it could make alot more with boost raised to whatever is safe
Edited by r31turbo
car would weigh 1400 tops as ive been trying to save weight whereva possible... removed hicas + abs + alot of other crap... im trying to get it to 1300 ill have to weigh it
i hold my car in high regard as even though i know r31s arent everyones cup of tea i am an enthusiast and i paid alot for this car over a r33 and over importing and complying a 32gtr.
Edited by r31turbo
Hey thats great to hear
yeah tis good, but theres so much shit wrong with it, got some rust
the interior looks shit as, got no key for it :P , needs new shockers
needs all windows replaced, coz they've all got yellow paint on em
probably has alot more wrong with it but yeah, i'm gonna have no
money left :
Guest
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
