i just changed my avatar pic vange, what is it your having trouble with? it took me a while to get it working
i choose the pic from my comp, i did a totaly diff pic..i chose a pic of a monkey, and the 1 i got now comes up...all blured...
  • Replies 6k
Posted Images
hhmm, Vange..... you got a damn good 'bod (if that is indeed you all sun-tanned in the avatar pic) is all I'll say :teehee::O
On a side note, your previous avatar picture, going back a few months, with the front end of your white R33, looked TOO MUCH like a Lancer. Why is it that on some angles, white R33's from the front look like Lancers?
i was just thinking b4....we had the problem that we didnt know when we c another skyline if they r on sau or not...well i have that problem lol
instead of stickers, how about a special 'signal' so we know..
in most cases, we c the other car travelling in the opposite direction, so how about when we c other lines, we flash our breaks a few times, and if they do the same, u know they r sau :)
also if they r behind u, flash ur breaks, n respond with a quick flash of the highbeams. same would work when crossing paths at an intersection.
any1 else think this is a good idea, or should i just shut up?
we discussed this a while ago....doing the nod, 1 finger off the steering wheel etc...too damn hard.
Everytime i see some other knob in a jdm car out on the road and im in my line, they are always looking at me sly to see what im driving for some reason, or they have a mate with them that is breaking his neck to have a look...what the f**k is so special about other peoples cars?? Especially my beat up wreck??
I undertand people seeing others they know, but racing, and trying to "impress" me with doing skiddies on the road aint funny at all....it just draws attention to me, which isnt cool if i get defected!
Guest
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
