  • Replies 6k
Posted Images
WOW - got my bush bearing high flow turbo today - Sliding Performance RB25 rated at 250rwkw at 1bar.
Im hoping for around 200awkw at 1bar once dynotuned at Graham West autos on the 4wd dyno, the safc and sitc will need a fair tweek I reckon. But I'll tell 'em you got 3hrs to do the job :happy: hehehe dont want to spend too much.
But putting it on the Stagea on Monday - cant wait !!! so excited ! :sorcerer:
hopefully it all works out smoothly, a backyarder install job so it'll be fun.
Im a bit limited atm tho to kneeling and all that, yet.
Plus I dont know when I'll be able to get it tuned. So I'll keep it to 10psi for now. :P
anyways, happy days
Brendan, all the best with the turbo install.
Actually I was just today wondering why the guy that tuned my car only left the boost at 11psi?! He reckoned if he put the boost any higher it'd hit boost cut - is that true? I thought there was no boost/fuel cut or anything - its just if the ecu detects too much airflow it will hit R&R??
Made me wonder if I took it to a different tuner would they be able to get more power out of it....hmmm.
yeah itd hit R&R (not boost cut) - but thats what your safc is for. plsu maybe a z32 afm sometime down the track. with a front mount and a tune at 1bar youd see good results.
isn't the stock r34 cooler meant to be good for 200awkw or close to? sure it wouldn't be at max efficiency at this level but I'm thinking I'd just get the power first and worry about that later - as long as its cool enough. One step at a time :P
I want to boost it to 14-15psi eventually (like u said ~1bar). THEN it can stay like that (think i've said that before lol).
Also the z32 would only be necessary once the stock afm is maxxed out - correct? still a little way off yet. I reckon I could squeeze another 10-15awkw out of it just by upping the boost and re-tuning...what ya reckon?
I'm getting 13L/100km city driving to/from work with aircon on half the time which I think is fantastic. I've seen 12.5L/100 and that included about 10% with aircon on...so I reckon there's still more leeway for more boost yeah?
Also, not sure why but my stock boost solenoid is still connected up to the intake piping as per before (not connected to wastegate tho - only the manual boost controller connects to that - and it appears to be done properly). Not sure if this would affect my boost level somehow - could be why its dropping off to 9psi?? Most people had good results with the needle valve boost controllers holding boost...but not me. If it held 11psi all the way I'd pick up 10awkw just there...
sounds great !
my thoughts are, with the safc, if you are going to retune it for more power; a) either tune for more power say at 13psi and pick up that 10+awkw, perhaps using a good EBC, or b) tune it once so supply the good EBC, a good FMIC and a Z32 afm and do it all at one, hell maybe even a bosch 040 fuel pump.
just that with the safc, if you add a fmic on right now your tune gets a bit outa whack - I noticed this with an aibox mod and also with the fmic install I did. ebay and it was cheap. ;) with the safc if you add bits and pieces here and there it puts the tune outa whack, etc.
she'll be right, all in good time hey. :P
sounds great !
just that with the safc, if you add a fmic on right now your tune gets a bit outa whack - I noticed this with an aibox mod and also with the fmic install I did. ebay and it was cheap. :P with the safc if you add bits and pieces here and there it puts the tune outa whack, etc.
she'll be right, all in good time hey. :(
yeah i was thinking about that too - even if I just want to wind the boost up a bit - it'd need a retune to work properly.
Not worth the $$ for a retune just for 10kw gain in my opinion. so i decided its better to wait until the next "upgrade" stage and do multiple things at once. better value for money that way...
still, no rush. Have been over the moon about the performance of the stag since my last tune. :P
that is, except for when the weather is hot, and the aircon must go on - turns the car into a slug, needing much higher revs than normal to get it to move :/
nothing better than taking the car out for a thrash on a cold night...makes it really go! :)
A little way to get around the R&R is to bump up fuel pressure and pull a heap of airflow out of it. The only issue with this that the ecu essentially runs on a lesser load point that runs more ignition timing. This will gain you a little more power before you hit r&r but after that you really need to drop an ITC on it.
OR... See Apexi are canning the Powerfc and have a type of piggy back full ecu replacement.. so still use the stock ecu but runs as a emanage type piggy back setup. It appears to look the goods and hopefully as they are canning the pfc it will be just as good as a full ecu.
sounds great!
will look into it for sure :huh:
there is a nude male wrestling seen in which there is various sex position action which is highly disturbing. other than that borat is worth the money. he preys on americans total ignorance and stupidity and even made money off the people in skit. they are all real as they are skits. truly ingenious.
Cubes - any suggestion on how to (calmly) :) put the top turbo water feed banjo hard up against the turbo and feed the bolt in? Due to using the washers its just too much of a handful........
The top water feed?
You mean the side water feed/return? The top feed should be oil.
The side water feed/return closest to the block can be a pain in the arse as the inside washer falls down easily. I have in the past used a little petroleum jelly to hold it in place while I get the thread to take as it can some times be slightly off and quite stress full. :)
yeah, cheers mate. My thoughts late last night were to stick the washer down first with something, say oil or grease or gasket goop etc, and then get that thread to take.
oh well, back to finish off the job
ta mate.
Guest
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
