Did they say why they couldn't remove the rear left wheel?
Lock nut? Spinning stud?
Either way you should be able to spin the wheel around and see with a torch how much meat is left on the pad. Looking at the opposite wheel will give you a good indication how much meat is left on the left.
The skylines brakes wear fairly evenly due to being 4pots up the fronts and 2 pots at the rear. So the inner doesn't wear early like that of the usual clamp type pos brakes.
I wouldn't be concerned.
Have you bought it yet?
Get under the car and check the chassis rails for damage.
  • Replies 6k
Posted Images
yup :wave:
hey guys i need a little advice, im purchasing the car on friday but there is a small problem and that is the RAA couldnt get the rear left wheel off the car to check the brakes on that rotor.
Got any advice, should this sort of thing hold me up greatly?
why dont you take it to a workshop that specialises in skylines? RAA is pointless when it comes to these checks, they only good for when your car breaks down and needs a tow.
yup :wave:
wtf? Id be wondering why they would not be able to take a wheel off...cbf, or something wrong?
I'm not too fond of the RAA inspections.
I bought a VS 5ltr 5speed some 7years ago, had it RAA inspected and they missed an obvious inlet manifold water leak and loose engine mount that had the exhaust hitting the body under acceleration. :wave:
The inlet manifold leak was a real pain in the arse to get fixed too.. They had the car for 3 weeks and racked up almost 70km's, I got it back and the clutch felt all spongy like they had been slipping it. :)
From there that car was down hill... Such a damn unreliable (drivetrain) money pit. Well at least the new owner got a good deal; new diff, gearbox and rear subframe. :O
The RAA said that "several of the wheel nuts were damaged, so unable to complete brake check."
The guy did a very thorough report and they do check everything on their check list. I mean id want a full refund of the 200 dollars i spent to get myself some peace of mind before buyin the car.
I'm not worried about the brake pad, Im worried about the wheel coming off, I think im going to tell him that I'm not coming to pick up the car until he can get that wheel off and then refit it with new nuts. without breaking his nuts is the key, but i guess im the one with the cash anyway.
Edited by SAZilla
so he has to brake a nut to get the broken nuts off :dry: how do nuts get broken...id ask for explanation.
he is thorough, but did they do a compression check?
yes, came up with 5 percent within eachother,
is that good?
@cubes, private sale bud
my mate said if the problem is that serious ill have to spend quite a bit to get the thread welded back onto the rotor or whatever to repair the damage done by the nuts. only problem me and my mate -who knows quite a bit about turbo vehicles- picked up was just a scratch on the door that could be buffed out and thats it. the car was beautiful on the test drive.
Edited by SAZilla
Update: I rang mike said to him id pick up the car on monday definitely if that wheel was removed then refitted succesfully, he agreed and is getting a mechanic to do it. so thats sorted...
so yer 5 percent is what the RAA said, I gather thats 5 percent loss or 5 percent difference between all cylinders.
5% variation is a fair amount but I'd say its most likely <5% which is considered ok.
The chances of a car thats 10yrs old having near perfect compression ratio is slim.
Please cheak the head lights when you pick it up... I was excited and forgot to... Turned the head lights on and then had to hunt around for H3C bulbs that absolutely no one had apart from autobarn that was closed. :dry:
yep the lights in her have been changed already, all but this rear wheel bullshit is fine. all the suspension and undercarriage is fine aswell but he couldnt check out that disk and that wheel and anything behind it. i rang the guy and told him to fix it for me today so i can pick up car on monday. so hopefully all goes well
easy
when i go to pick up the car, with my mate, I will say:
"fixed that wheel?, I want to just check the brake pads and the rotor before I give you the cash."
then ill check it, find that its all good, and then bang im done.
Guest
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
