  • Replies 6k
Posted Images
Same...
Jess would be whoring the crap out of siktown in the nsw forums... how big is the party going to be when she reaches 10k posts... You got Dan here complaining that I have 1,200 almost and Ive been on here less time than he has... but hes in the military so he should have like 20 posts and not 1000... lol.
no posting on my watch dan...
bah go run the gtr off a cliff (NOT).
Who here is actually "Working" at work?
Lol...always whoring, everyday...what is work?
Doing bits and pieces........
If theres not much to be done then, theres not much i can do!
Yep Im the same :)
Same...
No I whore up other threads now like central coast and hornsby and yours :laughing-smiley-014:
Yeah im not far from 10k post!!!
Post party FTW!!!
Same...
Your post average is at 7per day, Dans is at 4per day, and i'm chillin on 3per day!
I believe you are the whore Pauly..........
And as for Jess.......... well she beats us all at a solid 8per day and she joined a good couple of years before us!!!
Edited by Deluxe
>_< LoL I have done 9000 post since I moved to Sydney a year ago...You guys just need to step up the pace a bit
ur all postwhores :sick:
Wanna be!!! :laughing-smiley-014:
meh
*starts chanting* Post whore, Post whore!!!! :laughing-smiley-014:
Same...
lol group hug for the post whores ;)
nice ride Jess you mind telling us how much
lol yeah, ive got a fair bit of posting to catch up on :wub:
Yes you do lol!!!! :laughing-smiley-014:
I've either gone really colour blind, or shes not white?!?! =P
what happened?? =(
No I went for mechanial A1 over colour but she is getting a respray!!! :(
lol group hug for the post whores :wub:
No price is a secret!!! :rolleyes:
But she is fully sik and I love being a GTR owner :kiss:
She is my work in progress :)
By the way peeps I have changed my name to suit the new purchase :wub:
Same...
Yeh looking after your sorry arse so you can be the post whore :laughing-smiley-014:
No I went for mechanial A1 over colour but she is getting a respray!!! :ninja:
No price is a secret!!! :nyaanyaa:
But she is fully sik and I love being a GTR owner :nyaanyaa:
She is my work in progress :nyaanyaa:
well congrats Jess!!! :nyaanyaa: looks like a fantastic car =)
if you went for an A1 mechanical car, wheres the money shot (of the engine bay)? picsor...else!?!? =P
what future plans have you got in store for her? white respray is 1 of them im guessing :nyaanyaa:
well congrats Jess!!! :) looks like a fantastic car =)
what future plans have you got in store for her? white respray is 1 of them im guessing :)
Thanks :P
Yep white respray is on the list as with a few other mods its still early days and havent made any decisions I have only had her for a week now :)
But she will be turned into a Track weapon later on ;)
Here is the engine bay but she is stock (got to love the earthing kit lol)!
Guest
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
