Hmm nice...
Cause I have a mis fire issue at the moment in the GTR so might be upgrading the coil packs to splitfires and they are good!
Did you have a mis fire shaun? or just upgraded for the hell of it?
Phew!!!
he had a freakin crazy misfire, wasnt fun.
Yeah it does come down to price doesnt it...well I hope it all goes well :)
heh, always comes back to money.
the gtr's still on the list, but i might wait til im in another job.
  • Replies 6k
Posted Images
Aww Coil packs are a common thing to break :thumbsup: and looks like that will be my problem also...My car sounds like it has some lumpy cams, its cool but for the wrong reasons :)
Thats fair enough.... so what is this soarer..... year,colour, mods??
So we should expect you on the cruise this weekend Shaun :)
Probably not as not sure how long it will take them to do my front bar as they are quite busy at the moment.
I hope to be out though with the top secret front bar in place though.
Mine sounded like a WRX on roids. lol
It wasn't good at all, now sounds like a skyline and goes heaps harder than before.
Big thumbs up to splitfires, well worth doing even if you dont have a misfire.
silver(ish), grey leather int, comepletely standard, lol, tis just a cruiser.
but after just stepping out of a friends gtr... guh, lol, might end up not buying it, ah, decisions decisions.
Edited by scandyflick
LOL My sounds like a dragster at the moment
Where did you get your split fires from?
Glad she is all fixed up !
Oh so nice then.....I like a cruising car they are cool ;0
LOL you are making it hard for yourself but should rush into it!!
any1 here watch the Today show??
they were in Adelaide this morning hehe, i got there at like 5am
just so i could see Human Nature :thumbsup:
my friends mum was saying that they had the cameras on us alot lol
oooooooooooo i hugged Humphrey B. Bear :(
Guest
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
