  • Replies 6k
Posted Images
Was just wondering if SA had any cheaper but I found one for the $600 mark and its here in Oz :(
Thanks Maz
From what i know the black ones are...just black...and exactly the same a silver ones. So unless you REALLY want a black 1, ur better off (cheaper) getting the silver one. And if you come to SA, hide it in the glove box :(
some really loud whirring noise in the engine, im bit clueless when it comes to engines but im beginning to think its one of the belts. Really loud when i start the engine and when it on idle.
Hopefully off to mechanics tommorow if i get time and hopin it wont cost me too much! Belts arent normally too much to replace i dont think?
Yeah pretty much. I thought it was making a strange noise several days ago,but then it stopped and everything seemed fine but then started again today only alot worse this time.
Could be the bearings in the pulleys that your belts sit on...they can make a whirring noise and do ware out ;)
well, ive had a f**king awesome day so far.
didnt finish work til 7, went from there to the gym where i spent an hour being bored and tired on the treadmill before my appointment with my trainer, spent the next hour and a half getting my programme sorted, went to maccas to get a coffee afterwards, who'da thought itd take 4 attempts to get a flat white right? and then, my car wouldnt start.
awesome.
so i spent the next hour and a half waiting for the friggin raa, now i gotta go out and get some last minute birthday shopping done, might be able to squeeze in an hours sleep before i have to be back in town at 6 for a friends 20th bday dinner and then to work for an 11pm start. *sigh*
busiest night of the week and im going to be knackered...
fun stuff.
oh well, spose i better stop wasting time on here.
take it easy folks, its gettin pretty wild out there, dont wanna hear about anyone gettin hurt.
Ok yay all good! Stupid me hadnt checked the power steering oil/fluid in a while and it was runnin on empty thus the loud noise it was making. Mechanic said if i left it any longer i woulda damaged it. Phew. $5 and all fixed :bunny:
Why is it the more you know, the more you don't really know??Igonrance and stupidity are bliss. Or maybe they are not... :) Maybe life is way too complex. Or am I over looking something?
Simply I have no idea of what goes on anymore anywhere!?! Stop. thinking. NOW.
Why is it the more you know, the more you don't really know??Igonrance and stupidity are bliss. Or maybe they are not... :worship: Maybe life is way too complex. Or am I over looking something?
LOL
Yes I love to switch off.....its called going to sleep :laughing-smiley-014: :laughing-smiley-014:
Guest
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
