  • Replies 6k
Posted Images
Sept 10th at Boostworkx
Fit cam gear (supplying group buy Aerospeed item)
Install Oil filter relocation kit (supplying Greddy item)
Oil change (z145 oil filter + Motul Turbolite 4100 oil)
Attessa Flush with genuine quality fluid
Retune inc remove and refit tailshaft (safc / sitc / 15-16psi not sure yet)
Install braided lines and bleed system (supplying Maltech lines and Castrol super response dot4 fluid)
Install Front rotors and pads (supplying Dba slotted rotors and Bendix advance pads)
got a good quote, so Im happy with that.
cant wait
looking to "feel" around 200awkw I suppose.
nice tangles. 200awkw is ballsy.
lol, cheers :laughing-smiley-014:
blue-ballsy ?
hahaahah
yeh, at the end of the day, I bought the Stagea 2 years ago with an overall budget of 30k in mind (incl 18k for car) and a setup safe for 200awkw. which is what it'll be. brakes/suspn/engine all "tuned / setup" for the HP output.
only thing missing would be the auto tranny to be serviced + shift kit; all in good time tho.
Brendan - sorry i didn't catch up with you this week i been not well since Wednesday i thought i was going to catch up with you on fri but got worse then i couldn't even talk had to get my mum to ring my boss to say i wasn't going to work ... is there an emotion for how embarrassing ;)
anyways im feeling a little better now so i imagine i will be able to catch up this coming week
well im back @ work i finish @ 3:30 Brendan i will run by the city on my way home :cheers: but where excactly will i be running when i hit north tce if i ring you are you able to meet me on the street jump in the car run around the block and drop you back :P or something like that so i dont have to get a park
Guest
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
