  • Replies 6k
Posted Images
Made 268rwkw @ 6000rpm on 15.5psi with the GT3076r .82 yesterday. ;)
Pushed more boost (up to 20psi) in but as it pushed past 275rwkw the curve got all spiky; no det issues just a messy curve.
Shaun seems to think its the baby 232duration 7.3mm lift exhaust cam in these r32 rb25de heads.
Pushed in another 2 degree's and saw 270rwkw peak but not worth the 2rwkw; there was no det but I'd prefer to pull 2degree's for only 2rwkw.
Afr's are mid 11's dipping to low 11's after peak power is made.
Not sure whats up with the clutch; shaun did say it felt high but was holding in ok on the dyno; so maybe it gets a bit hot on gearchanges and then starts to slip?!? :S
Should see a fairly easy 300rwkw with the GT30 going by how much ign advance Im able to run and ~270rwkw being made on only 15.5psi. :P
:waves:
Jess how much would i be looking @ for GTR hubs for 5 stud conversion
be back @ lunch :)
Hmm will find out a price for you tonite! :(
If there here in sydney tho I cant freight it through my work like I did last time as I have changed jobs! :P but will be able to sort something else out I reckon!
anyone want a track car??? 58sec Tsukuba time
http://www.racecarsdirect.com/viewlisting.php?view=7965
would be a nice lil car for some runs out at Mallala
yeah i would you can buy it for me for Christmas just as Kraster hes Satan Claus
25,000.00 GBP
61,865.52 AUD
Morn Jess , Guys
i was searching around last night Jess and other people that have done 5 stud conversions have been using Stagea front hubs
i can source R33gtst ones here from a guy i bought my front rotors from
im just getting ball park figures @ the moment and buying it piece buy piece otherwise ill never get the conversion done :)
Just feeling like having a whinge.. DAMN CAR!
Mine is just costing me more and more.. Just spent $350 on god knows what.. took it in for oil change etc and discovered shes leaking.. everywhere. Nice big mess under the bonnet! Needs new everything! Hoses n piping.. I have a possible turbo leak or something.. Injectors may be screwed..
Missing on idle really bad.. Probly need new coils while im at it.
Theres a massive list i just cant remember them all at the moment!
No wonder im always broke..
Car was a bit of a mess when i bought it just over a year ago, and problems just keep appearing grr.
Ok whinge over
How was everyone elses day?
Guest
    • you can enter your VIN (the original, japanese one) here to find the correct part#: https://www.amayama.com/en/genuine-catalogs/nissan however, after all this time it is more likely to be a wiring issue than the sender
    • no, it was the same here, just flurries but no need to get the toboggan out....but it is exactly the sort of days where its good to have some inside jobs on the list. Speaking of which the fuga is driving properly after 2 1/2 years.....but that is a whole other thread
    • And yes, put in the restrictor while you are there; a standard engine is fine with a little less oil and you are less likely to run out of oil if you have sustained high revs for any reason eg visit a track one day. How did you clean the cooling system
    • I didn't think about how a circle works before, dumb.  Before, I had .9mm restrictor bolts but I can't use these cause they were shorter aluminium bolts that just tear off their threads when tightening since the OEM lines are thicker than the shitty braided one that was installed previously. Now I use longer 1mm stainless steel restrictor bolts. I think the difference will not affect the health of the turbos, but I guess I'll have to drill out the main feed bolt as I agree multiple restrictions sound dodgy. The one that was installed with the braided line was just too short, but completely without a restrictive hole.
