yeah shes lost 5 front teeth :)
only 2 rides ferris wheel and crazy coaster i wasnt quick enough @ the end of the ride to take a photo of the LCD tv where you could buy a photo her face was priceless
looks like a nice camera Lee
Edited by Madaz
  • Replies 6k
Posted Images
Is it raining in SA??
We just had 3 days of it here and it rained out my drag day :spank:
So want to do a time in my car and she is going to be even quicker soon...Cant wait bring on 300+kws *rubshandstogether*
We have our first SAU NSW motorkhana this weekend...im entered and helping run it and should be loads of fun but nervous as first time :(
Yep Jess, rained pretty hard here this morning! Cleared up a tad now but still overcast. That sucks about the rained out drag day :wave: Sounds like your baby is turning into one hell of a beast!!! :wave:
Awww thats suxs but good for you I guess...DAY OFF!!! WOOT! :(
I know so want to do a time!!! Yep its getting there :D and is going to be white soon...cant wait!!
i would say they wouldnt pass it if they see it, suppose it depends how obvious the cuts are too, cause they wont be pulling your bar off to look, so they might just see its there and move on.
f**king GWW (marion rd)
charged me $1200 2yrs ago for a full timing belt, water pump etc 100,000km service job
got the car in at Boostwerx today (got nothing but high praise for Troy and Shaun), been losing fluid hardcore. water pump needs replacing. I bet 2fknhundrey that GWW never replaced the water pump.................... overcharging bastards they are. rang em up, after having 2 tunes previously - $500-600 for tune (boostwerx - $200). I figured then they were over chargers, and since sampling Boostwerx in March this year for the first time, well, I wont ever be going anywhere else.
Certainly not GWW
If you are reading this BW; dude, why overcharge your customers, and dont do work that has been charged? That spells "losing customers" and ffs youve lost me thats for sure.
end rant. :D
SO f**kING STRESSED WITH THE KNEE OP ON THURS7AM
FFS
Certainly not GWW
end rant. :)
FFS
I stopped going to GWW a couple of years back now after being way overcharged to get my clutch looked at. I have found my self a nice little workshop down at lonsdale. The guys there mainly do rotars for drag cars but did a GREAT job on getting my car up and running smoothly ( especially as it was the first skyline he worked on) and he only charged 1/2 the hourly rate of GWW :yes::) :)
good luck with the op Tangles
Flick:
Sad to see it go, but houses are never going to get cheaper and the longer you leave it the worse it gets. BUT once you are in, as long as you can afford it, skyline it up again!! ;)
Would you consider swapping rims with cash your way at all? If so, PM how much diff you would be looking for :)
Guest
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
