  • Replies 6k
Posted Images
Flick:
Sad to see it go, but houses are never going to get cheaper and the longer you leave it the worse it gets. BUT once you are in, as long as you can afford it, skyline it up again!! :D
Would you consider swapping rims with cash your way at all? If so, PM how much diff you would be looking for :P
Willl let u know.. atm im having second thoughts bout selling. I love my car, more than i should love a car lol. Its part of who i am.. and im making myself upset just thinking bout selling lol. So for now.. im going to think bout it for a while.. maybe hold onto her for another year ..
I feel that selling my car for example is like losing a limb, WAAAH. It might as well be :D Its never going to be easy!
But I too need to sell as I am looking into getting a place (whats worse, in PERTH! super expensive!) The only good thing about it is that the company that I'll be working for takes care of all legal costs, stamp duty bla bla upto $30k... for me!!! Thats an opportunity not to miss... especially for a poor uni student like me :)
I was on you tube looking up random stuff in australia and i cant belive YOUTUBE can let all the racist stuff on there. It's crazy they pick on all the car hoons on youtube but all the racist stuff is crazy WHAT IS AUSTRALIA comming 2. It might be old news but it hell shocked me
Hey, happy birthday Pauley!!!! so where we going for the SAU lunch next week to celebrate?? =P
oh and I know its a few hours early, but good luck with the operation Tangles!!!! hope it all goes well for you!
Edited by Fishpaste~
Hey all
anyone head down to that dyno day for nissan vs toyota me thinks toyota may have won due to lack of nissans :laugh:
i recon if you have to go barreling over small trees and shrubs and what not you would want to do it in this
The toyota turn out was a little poor.. :)
A heap of 70-low 100rwkw toyota's with one that cracked 160 something rwkw.
I picked up second spot with darren picking up first with a massive boost leak. rbmans had dropped boost to 12psi and Im certain mine is valve springs :( arg.. the joys. :laugh:
Guest
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
