  • Replies 6k
Posted Images
will, it need to be a very high pressure compressor that is able to pump the paint to a fine mist. correct me if im wrong sam.
half right duc, any air compressor should be able to turn the paint into a mist, its jsut the compressor will need to have enough puff to do a whole car. with my old compressor (2.0HP) i had to stop spraying 4 times (painting a bonnet) to let it build up more pressure.
yeah, but it will look awesome when it's finished - and if you took it to a crash repairer it would cost you $2k+ for an inferior quality job.
Yeah, Will isn't too much of a drinker these days, so he is normally happy to be nominated driver!
hey Sam - I am not going to do it soon, but assuming my R34 4 door's paint was in v.good condition, and seeing that it's black already - would it be possible to do a light rub down and do some minor pin dent/scratch repairs, then do a couple of coats of midnight purple over the top? Or would it need to be rubbed right back anyhow like for a complete respray? And/or, are there any other options to freshen up paint to brand new, like adding a couple of coats of clear or something?
Also, a few years ago I saw a car in Adelaide that was painted dark purple, then the clear coat had a harlequin type sprinkle actually in the clear coat. Is that easy to do over an existing colour?
Ill have a look at the paint on your R34 for you when it gets here, chances are a buff & polish will bring up the paint like new.
Yep, its possible to do that
Ive noticed that nissans solid black are done in clear over base, so that would be an option, my only problem with doing this is although the paint will be nice and glossy any minor dents will show up even more
The harlequin itself is actually a transparent layer put down over a black base. seeing as you car is black already, that would act as a base. so steps would be - light sanding/scouring of existing paint, 2 coats of harlequin layer, 2 coats of clear. I would definately recommend that all minor dents are repaired in this situation, the smallest of panel imperfections will ruin the look of a harlequin job.
Hope that helps you out a bit, will give you a few options to think about anyway.
Sam
Use the compressor with a sander to help with the prep work. (anything beats dooing it all by block)
Definately, its way quicker to use an orbital hand sander. the only down side to this is the panels will look all rippley when you look at them on an angle. Using a block or a file with the correct method will give that nice straight look to a panel :thumbsup:
Sam, I know it is a hard question, but can you ballpark me the last option - fix say 6 small pin dents/scratches, lightly sand back whole car, touch up repair work black (as a base), then 2 coats of harlequin, 2 coats of clear? Just roughly, assuming I help you sand and its a private job .... also could you sort of ballpark quote it as an official job through your work (including GST) - as it's a work car I get the tax benefit that way :) .... I won't hold you to it - just wanna know roughly. This is all pie in the sky stuff ... but it's nice to dream :thumbsup:
yeah, thats a bit of a tricky question. i'm not totally up to speed with the way pricing is done, i just put the paint on the cars :). I know that there was a 180SX done by a shop here in SA in harlequin, and all up the price was about $15K. With my own pricing, i havent really got anything solid. My main problem is access to a spray booth. My boss is reluctant to let me even do my own stuff in his booth, he fears that it looses him business. I've tried painting 2K in the shed a few times, and it doesnt work too well, all sorts of dirt, rubbish, bugs land in the paint. But yeah, have a think about it and let me know what you wanna do.
Guest
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
