  • Replies 6k
Posted Images
i can post every 30 secs still :D
haha yeah i get bored at work so i just jump on the net .... govt worker haha well its actually my last week,
No i dont know how it happened :D the other side was rusting up so they replaced that too .... and my discs were in soo bad need of machining they had to actually take them off site cos their machine wasnt 'heavy duty' enough to handle the job. They said i was VERY lucky and they didnt charge me for the brake lines.
not moving :) Besides i couldnt have my plates in SA cos they are on a 200sx over there haha :) I'd feel naked without them.
Coming over for JMS Drift Day with a couple of the Perth Boys.
Govt work is pretty cool - ive been here since Feb and its only in this month they've cracked down on internet usuage and started monitoring ..... but who cares by the time the bss get sthe report ofr this month - i wont be here :D
Had the pleasure of a close inspection of a new commodore today. What an absolute POS.
Bumper was loose and rattled
trim around the seat rails was loose and wouldnt go back on
factory floor mats were too soft and wouldnt stay in place, plus the trim was loose
plastic fittings in the centre consol didnt fit properly and were loose.
THE CAR HAD JUST UNDER 5500 KM ON THE CLOCK.
Seen better quality in a LADA NIVA
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
