or we could have it at my place - I have a projector and big screen :) .... just gotta figure out a way to get rid of the wife for the night :)
Love your sig avi Duc ... go the R34 4 door :)
I'm off to play some BattleField 2 Demo now, so won't be lurking anymore ..... catchas later
  • Replies 6k
Posted Images
Can I have your opinion on this guys. Thinking of getting it as my daily. Dont laugh, serious question.
Hey duc!! If you want one of those as a parts runner, be cheap as on the old fuel, and a little bonus is, they come out with the E15 motor as seen in the little ET Pulsar(turbo), would be a sweet straight bolt in engine change. and not to mention some fun!!!
If they had one avaliable in adelaide, then sure i would think about it. Would be wicked to transport parts ie bonnet/bodykit/wheels around in that thing. Imagine the looks you would get driving down a street like rundle st in that thing. Hehehe
nice pics there duc.
sanding work looks good, but its hard to tell from a pic. looks like youve been using water too, just a tip - clean all the sanding sludge that has run down the front of the car up with a sponge after you finish sanding, if its left for any amount of time or the sun gets on it it can be hard to clean off later. :)
hehe
oh btw sam, say if i was to paint it in acrylic would the acrylic primer be ok on top of the current primer that is on the hood or do i need to sand back to the red coat underneath that. I know that acrylic/2pak dont mix, so im kinda dumb founded.
just prime straight over the top, no matter what paint it is, it would be dificult to sand the colored layers off by hand. you just need to keep in mind that the acrylic paint has more of a chance of 'biting up', than 2k
like how the guards looked before you sanded them, you could see all the sanding marks in the paint. also on the bootlid where they removed to spoiler & patched up the holes, you can see the 'bite up' lines where they put the poly-filler
taking bout hands, i have like blood blisters and crap cause of the sandpaper :pissed: My thumb and index finger are so sensitive now.
really? ive never had that before. if you have sensitive skin, be careful when using thinners & solvents, that stuff has recked my hands.
yeah i cant stand wearing gloves - pansy!! hehe. so i just use my bare hands and a block i made to sand it. I think the hrs upon hrs of my hands (right one) being soaked has not helped it.
Guest
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
