as some of you guys know, i have been looking for a new car as of late, most likely a skyline, however today, i found an offer i couldn't refuse, a black 1990 nissan Sil80, it looks awesome:) so i put my deposit down and it's all sorted, however i was wondering if i am still eligible to join SAU and come on cruises with you guys even thoguh my car isn't an RB, would be awesome if i could:D ta
https://www.sau.com.au/forums/topic/148490-please-dont-shoot-me-__/
well i just bought it, and never owned a turbo before, so juts gonna learn how to drive it before i start to push it, last thing i want is to smash up my baby haha, it's pretty stock, hks BOV, HKS Pod filter, front and rear struts, 18" rims, turbo back exhaust, in the ca18det, so it's by no means a monster, but it has enough power for me:) when i learn to drive i will be goin to the track heaps me thinks:D:D where abouts are you from? would love to meet up and compare:D what you got done to yours?
there are evos, supras, 180s, silvias etc etc - hell if i wanted to, I can place the sau stickers on my 82 civic.
its not about the car, but more for motoring enthusiasts...
sounds like an advertisement for shannon's insurance :)
he's is full dorifto spec yo.
Nah ryan's is a piece of shit, honestly it is.
But it is still better than a lancer.
HAHA says Captian Bigbird of HMAS RBoat32! Yarrr
Mine is nothin special, mostly suspension stuff. Best bet is to come along to one of the meetings, they are the 3rd tuesday of every month at Bells Hotel :P
You know, if I wasn't hundreds of kilometers away from society (Patty Lakes), I'd come kick some balls. Besides - my Lancer is doing pretty well at Gran Turismo this morning.
Haha, a playstation driving a playstation. Unbeatable
the pics will come once i get the car:D so first week of janurary:D man i'm sooooo excited hahaha yer for sure, would love to come down and party with you guys, how often do you guys hold cruises?? not necessarily huge ones, but just if someone feels like going for a cruise on a friday does that kinda thing happen often?
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
