as some of you guys know, i have been looking for a new car as of late, most likely a skyline, however today, i found an offer i couldn't refuse, a black 1990 nissan Sil80, it looks awesome:) so i put my deposit down and it's all sorted, however i was wondering if i am still eligible to join SAU and come on cruises with you guys even thoguh my car isn't an RB, would be awesome if i could:D ta
https://www.sau.com.au/forums/topic/148490-please-dont-shoot-me-__/
well i just bought it, and never owned a turbo before, so juts gonna learn how to drive it before i start to push it, last thing i want is to smash up my baby haha, it's pretty stock, hks BOV, HKS Pod filter, front and rear struts, 18" rims, turbo back exhaust, in the ca18det, so it's by no means a monster, but it has enough power for me:) when i learn to drive i will be goin to the track heaps me thinks:D:D where abouts are you from? would love to meet up and compare:D what you got done to yours?
there are evos, supras, 180s, silvias etc etc - hell if i wanted to, I can place the sau stickers on my 82 civic.
its not about the car, but more for motoring enthusiasts...
sounds like an advertisement for shannon's insurance :)
he's is full dorifto spec yo.
Nah ryan's is a piece of shit, honestly it is.
But it is still better than a lancer.
HAHA says Captian Bigbird of HMAS RBoat32! Yarrr
Mine is nothin special, mostly suspension stuff. Best bet is to come along to one of the meetings, they are the 3rd tuesday of every month at Bells Hotel :P
You know, if I wasn't hundreds of kilometers away from society (Patty Lakes), I'd come kick some balls. Besides - my Lancer is doing pretty well at Gran Turismo this morning.
Haha, a playstation driving a playstation. Unbeatable
the pics will come once i get the car:D so first week of janurary:D man i'm sooooo excited hahaha yer for sure, would love to come down and party with you guys, how often do you guys hold cruises?? not necessarily huge ones, but just if someone feels like going for a cruise on a friday does that kinda thing happen often?
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
