Rb20 5-Speed w/ Tail Shaft Good Nick W/ Low Km Exedy Cushion Button Clutch - $800ono
Rb25 Coil Packs - Full Set $100
Rb25 Crank Angle Sensor - $75
Mint Rb25 Turbo W/Stock Dump (no shaft play) - appears to have fresh steel rear wheel SOLD!!!
Rb25 Manual Starter Motor $100
R33 Clutch Pedal $250
R33 and R32 Climate Control Units Got Both $75
R33 Ser II Tail Lights And Garnish $400ono
Cat Back 3" Exhaust Off R33 High Flow Cat and 1 Rear Muffler - No Pics SOLD!!!
R33 M-Spec Front Seats (were in my 32) Clean - $250pr
R32 RH Headlight - $75
R32 Stereo Surround - $50
R32 4 Door Carpet - $50
A31 Nissan Cefiro Rear Bar - Silver - $100
Located In Kedron Nth Brisbane
pm or
0421560017 Robby
Edited by rso84
https://www.sau.com.au/forums/topic/148498-rb2025-parts-r32-and-r33-parts/
can organise it to be full conversion, box, shifter, clutch, bolt in gear boot on floor, clutch bedal, slave cylnder, tail shaft, gear box mount... only think missing is muaster cylnder n lines... 1200
c'mon champ, update me.. you've had money for a week now.. whats the progress?
any sort of reply will do.. you've been online since i posted this, you've been online many times since i pm'd you last.. whats going on? you have my money.. whats happening?
WARNING! dodgy trader..
deposited money into his account for the RB25 crank angle sensor and havnt heard from him since. he ignores private messages and hasnt updated me since payment was made almost 2 weeks ago.
if anyone knows who/where he is, please go knock on his door for me.. cheers
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
