Hi guys, just letting you know the results from putting on the TRUST 710x305x165mm intercooler.
We first ran the car up as is and made 350AWKW
Once we put the cooler on we gained alittle bit of lag(not much) and then we gained 31kw at the wheels.
This to me was a great result.
I then had a bit of time to put on the 4" exhaust to see what would happen.
Yet another 30awkw.
We ended up with 410awkw
If i'm right thats 17% increase.
The car will head back to CRD in the new year. The goal is 500awkw on pump gas.
fingers crossed.
Next mods might be bigger cams and injectors.
Also a big thanks to the guys at CRD for the cooler, The guys at Hypertune for installing and piping up the cooler and also C&V for staying back late whilst we were changing the exhaust.
Cheers
Paul, I believe it.
The thing that most people miss when installing a larger IC is reduction in restriction.
I'll use the analogy of upgrading the stock IC. When people upgrade the stock ic to a fmic, they usually see an improvement in power. The improvement is not so much from an improvement in cooling. Yes, the air will be cooler, but at stock turbo power levels, it doesn't really get that hot. The power increase comes from a reduction in restriction. It is restrictive at that power level.
In this case, at 350awk, the new IC is clearly less restrictive. I don't know if 30 kw is believable, but i would certainly expect some improvement at that power level.
Depending on what the old exhaust was, e.g. if it was a 3" exhaust with a couple of mufflers, a cat, etc, then that result is perfectly valid. Replacing a restrictive exhaust at 350awkw with a less restrictive one will produce significantly higher power levels, because of the larger number to start with.
Edited by MANWHORE
if he went from a poor mans standard gtst side mount stuck on the side there getting minimal airflow to a better/larger core in the front of the car getting much more airflow then i would agree, but is it really that much of a differenece? 30kw is a massive change, surely something else was changed at the same time?
for a 30kw gain i would have expected something like this;
previous intercooler
compress outlet temp: 70deg
intercooler in temp: 65deg
intercooler out temp: 62deg
new intercooler
intercooler out temp: 35deg
then yes i would agree that a gain like that is possible as the air has a significant temperature drop. how bad was the last core ?
Yep, agreed.
its larger, colder, and maybe the new core is of better flowing quality.
I know some one who has avl, they ahd a huge front mount already, and the car put about about 560 at the wheels., he put on this huge F*ck off cooler, of crazy dementions, and no shit, the car put out another 60hp odd. but response was out the window of course, but topend power was more. just cause the air colder = more oxygen.
its a drag vl, so he didnt care.
Paul, like I said above, when doing a power run, the intercooler will not really get that hot, so any improvement in cooling won't be noticeable.
The imrpovement comes from reduction in restriction. The cross area of the new core is significantly larger:
New core: 50325 mm squared
Old core: 30000 mm squared
Hey guys
I'm not going to try to prove anything here, people on this forum know that i wouldn't make up crap.
You gain extra power two ways.
1 less pressure drop across the core(less back pressure on the turbo.
2 reduce inley temps.
this car did have a trust 600x300x100mm core, but the power was dropping off up top.
We thought this was from a restriction of some kind which we thought was the cooler.We also knew that the exhaust would give me about that power because we have tested it before.The other exhaust is a trust unit and we had a cat removal pipe fitted.
I'll see if doughboy would be kind enough to put the photos up today.If there are any serious none believers just call C & V when they open back up.
You could have just run more boost through it, as it’s essentially the same thing. Colder = safer not necessarily more power. If you really did have gains like that, I would have to say your old core was a piece of crap or your advertising for CRD.
Hypertune did the fab work and install
C&V help out with the Dyno
CRD is a TRUST dealer who sold me the intercooler.
We run a TRUST T88-33d.
All we did was change the piping to suit the new cooler.
we already had a hypertune intake and 100mmTB.
AS for we could just run more boost thats right, but first we are getting the car sorted with what we currently have.
I'm not sure what the record for power out of a 33D is but we'll see what we can get out of it.
Also i'm not about to wind up the boost with the new mods when the car has not had a retune.
We want to make hte most out of our engine and turbo set-up, not just wind up the boost and see what figures we can run.
i would rather run more power on less boost, yes it mite cost a bit more but at least we can see what the engine is capable of.
Edited by 600hp
HRMMMM. this could be why im stuck on 307 awkw on 20 psi threw a t04z lol. (stock internal)
yet another thing to add to the list
That power doesnt sound right Dave :P Somethings definately holding your car back
My car is making around 15awkw more than yours at the same boost level with GT-SS's
This is one of the reasons we think our car made bugger all gains changing from GT2530's > GT-RS turbo's
the poor quality core was too restrictive...and was unable to flow the extra air the larger turbo's could provide....mind you it was 120mm thick but the core construction was old school and the newer technology cores flow a lot more air for their size.
Ben we have the same large core on our car (twin entry TRUST 163mm)...they are pricey but are certainly the "ducks nuts"
Well done with the results...see you in the new year mate.
Paul and Stace
Hey Paul,
I was very supprised with the results as well.
I'll drop around to Doughboy\s place tomorrow and drop of the photos .
We also took a video of the dyno run with the 4"exhaust.
Very loud.
Have a good christmas everyone.
Cheers
Ben
Edited by 600hp
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine and drivetrain will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe, give me my power goals I want and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
    • It’s almost the price of an engine build, you won’t have anything to bolt onto it though
    • Hopefully it's enough to help with the temps! I was also only shit stirring, regarding Murphy's Law basically. I've found, what ever spare parts I have, are the parts I don't break. Ever. Also have never had issues with oil/spinning bearings until I put oil pressure gauges on the car. 😛
