The lights on my gauge cluster are very dim. I pulled the cluster out the other day and found that there are little blue 'caps' over the globes. Are these normal?
Anyway I wanted to goto another colour, probably using LED's, any ideas on what would be the best lighting colour that I can still see?
TIA
https://www.sau.com.au/forums/topic/148530-changing-globes-in-gauge-cluster/
Here you go mate this UK skyline thread is great and useful....read all of it to find out all the tricks, including a/c and clock colour change....also hazard and rear de-mist LEDS .....hope it helps
http://www.skylineowners.com/forum/showthr...light=dash+LEDs
Edited by Allkiller
  • 3 weeks later...
I am also looking to change my dash globes, as well as A/c controls, ignition, clock, all lighting on dash to LEDs.
Can anyone run through a list of what to order and how many? Please!
Any help would be most appreciated!
ive been reading over this gear for while..
R32 cluster needs 6 globes .. colour of your choice .. Depending on your needle colour id stear clear of blue and toward green or red... blue is the brightest colour to the human eye so you can see why..
As for climate control air con you need to use led's I wouldnt use over 1000mcd which you can grab from jaycar or dicksmith.. you will also need resistors .. search google for resistor calulator to find out once you find the globes or even ask jaycar guys..
Two documents you will need are on SAU www.skylinesaustralia.com.au search for LED and cluster and should pop up.. or go directly to the tutorial option in the forum page 3 of results i think..
Follow them its easy as pie for cluster.. t10 globes.. same as park lights .. LEDs require some soldering!
Hi, only some of the LED's need soldering the ones in the A/C do not, they need unwinding drilling out and re winding with the new leds.......all the info is in the thread i posted its a bit all over the place but it is all there.
Blue or red come out best Green makes the Gauge needles very hard to see at night.
Blue looks very good....thats why most of the UK skylines have this mod.
And remember the LEDS only work one way round so if it does nt work turn it round...easy in the gauge cluster not so easy when you ve just soldered them in and both are wrong, AARRGGGHHH
Edited by Allkiller
if you want some realy good leds for the cluster goto www.superbrightleds.com and get the WLED-B5 leds. These ones light up the cluster realy bright and evenly, with all the other brands the color is faded in spots in the cluster.
on mine i changed the cluster, climate, cig lighter and key thingy.... the key thing looks realy cool from outside the car :(
whats this blue gel stuff you speak of :O ?? and how do u do it :O ??
Nice Justin....they are bright must be 180 degree LED's too.
have you put blue theatre lighting gel behind the clock and A/C read out yet....job done
Its the stuff they put in the lights to create colour....its calld Gel.
Most theatres have it and they will have bits they throw out when the centres get burnt by the 650 watt lamps.....wont happen on the Clock or A/C
I'd guess they'd sell or give you some real cheap.
You just place it between the clock read out and cover, same with the A/C..... means taking the fascia off again
Should look like this....dont use too dark a blue or you wont see the read out at night when it dims with the headlights on
  • 3 weeks later...
TIA
hey the caps ar normal on the globes thats how they come, ive changed my globes over to leds several times i found that red was the best to see the guages and the brightest when blue was just too dark to see.
on mine i changed the cluster, climate, cig lighter and key thingy.... the key thing looks realy cool from outside the car :P
That looks awesome, ive been searching for different options to change the boring standard cluster, was gonna go with those white reverse gauge things but might just use some of those leds, good work!
I did post a link on here a month ago from the UK site telling you how to do everything inc the rear defrost hazard switch and the A/C and Clock
also the Auto window switch in the door.
Blue works well....green is not to good as it makes the needles almost invisible....its al about light spectrum with the red needles.
try this again....
http://www.skylineowners.com/forum/showthr...ght=dash+lights
Edited by Allkiller
    • I did a bit of googling, the color MCM used was Galaxy Grey from House of Kolor. This is actually a colour I picked out about ~10+ years ago (or more). This one is a stock BMW colour, I guess over the years I figured it was smart to get an OEM colour that was pretty common for all of those sensible reasons one can think of..
    • I absolutely love having clean wheels and also totally love cleaning them. Its not as important to me to have a clean car exterior as it is to have clean wheels. So I bought a kit. I generally use different products for my wheels than anything else, so I thought I'd buy a proper kit and bucket to keep it all in. I got this one from Waxit. I also got the CQuartz wheel and plastic ceramic along with a bunch more application micro fibre pads as CQuartz never provide enough.  The kit was good, but as usual the big, long spongey thing didn't fit between my spokes, so I needed to use a detailing brush and a larger brush that I already owned (been doing this forever, the spokes on these wheels are frustrating.) I did a full clean with the wheel cleaner, it has an iron killing product in it, so I found that I could just use the cleaner and nothing else on the wheels. The tyre cleaner and handled brush were awesome. Made cleaning the tyres so easy. Once everything was clean, I decontaminated with isopropyl and applied the ceramic. Two coats. I bought 2 bottles as I have a lot of wheels to do, half of one bottle did two coats on these. The X5 has 20's so I reckon probably 3/4 on that. Then, for possibly the best part, the wheel cleaning kit comes with a tyre black applicator. But, this is possibly the greatest sponge of all time - its a great size, quite stiff and HAS A COVER! When you finish applying the black, you just put the cover back on! This is revolutionary, I normally have to try and find safe places to put my tyre black applicators as they are covered in silicone and tyre crap. Or, you use something which just falls apart. This applicator is the bee's knee's. Get one. It's worth it. The tyre black is also like a cream, its very thick but goes on really thin, its very easy to use with the applicator. Ayway, after a big clean, decontam, ceramic coat and tyre black the wheels went back on and they look awesome.   Thought I'd share.
    • Haha. Good work. I feel some of your pain because I spent a bunch of time under my car over the period too. Probably nowhere near as much as you did. My happiness is similarly improved by obtaining a desired result though. Those side skirts are.....hecking. Very unfriendly for street and hoist. Sounds to me like you've made a cart that needs to be driven up only planks/blocks at a 2 post hoist, rather than trying to get it up onto a 4 poster. It's very pretty, by the way. Somewhat reminiscent of Marty's squid ink on SuperGramps - at least in the photos.
    • Absolute Legend 🍻 After fighting with the scanned ones for the last 10 years this is a God send
    • ATTAKD 356mm Brake Kit for R34 GTT or R33 GTST. Same brake kit as per here from JJ: https://justjap.com/products/attkd-brake-kit-nissan-skyline-r34-99-02?currency=AUD Can confirm these will bolt directly to a R33 GTST with 12mm bolts OR to a R34 GTT (which is what I had) with the supplied bolts and the collets for the 14mm bolt holes in the R34, which are included. Also included is a set of rotors and hats, as well as 2x brake pad sets. 1) DBA XP (street, hills) 2) Forza FR6 (track) These are radial mounted and bolt directly to R33/R34. You will need extended brake lines to avoid them being full stretch on lock - this is common for all BBK's with the bolt point being in the center. In my case I welded another stud about 25mm lower than the OEM one and retained stock lines and fittings. You'll want a BM57 BMC to get the most out of these. I speak from experience. $1800 (neg for SAU people), located SE Suburbs Melbourne.
